on 02-09-2021 16:14
I have a PC with Gigabit connection connected directly to the Hub4 via a Cat 5e Gigabit cable - Distance about 4 to 5 metres.Connected to my hub presently and for all testing are my pc and my iphone 8. I previously had an M600 package with almost identical issues then whilst transiting to the 1Gb package, moved to M200 for about a week and that work flawlessly from start to finish!!!
I had 1Gb installed last week and haven't got anything greater than 943Mbps but overall average is around 4-500Mbps?
I have used countless speedtests and are generally in unison that my connection is slow - Realspeed Samknows shows anything from 350 to 980 but usually is in the 400's.My upload speeds are averaging around 50, latency around 15 and packet loss always less than 1.0 (last check was -0.121.
Regards wifi, my phone on last check using Samknows was 397 to hub and 319 to phone - Ookla test was 479 up and 49.5 down. Overall any test on my phone will show anything from 69Mbps to 500Mbps sitting right next to the router?
I'm confused as to why a) I'm not getting a decent speed e.g. always over say 850 and b. Why my readings are so widely variable?
Last speed test run/ethernet:
nperf.com: down 246 up 51.63
Fast.com: down 290 up 50
Samknows: down 390 down 293
Thinkbroadband: down 215 up 39.7
Ookla Website: down 351 up 52.84
Ookla Windows app: down 676 up 52.80
iPhone 8 Wifi: Ookla app: down 358 up 43.5 Realspeed Samknows: down 397 down 319
Answered! Go to Answer
on 15-09-2021 13:38
on 15-09-2021 13:58
on 15-09-2021 14:36
on 15-09-2021 15:11
Yea I am getting HUB offline each night/early morning at same time for a week or so now but it does not stay of long.
on 15-09-2021 15:21
Hello jhuk
Sorry this is happening
We do tend to update our servers at a time when we have the least amount of users online
I am not saying this is the reason , but it can happen.
Sorry if this is causing any inconvenience
Gareth_L
15-09-2021 16:25 - edited 15-09-2021 16:30
Hi Gareth_L
This thread was started to highlight my issue and you work (I presume) for VM? Could you offer some insight as to why I'm having issues with my line? On Sunday past, Zach - Forum Team requested I log my router numbers etc which I've done but I've heard nothing official since with no follow up?
on 15-09-2021 16:32
Hi ewhitey
I am happy to take a good look at this for you
Just so I have the right account
I will need to send you a private message to pass security
If you can check the purple envelope top right of your screen that would be great
Gareth_L
on 15-09-2021 16:37
on 15-09-2021 16:42
Thanks ewhitey
Appreciate you taking the time to send that
I'm just going to have a look at this now
Gareth_L
on 15-09-2021 16:46
Just a quick Message
As you have tested on an Iphone 8
The Maximum speed this device can reach is 580 - 709 Mpbs
Do you have any other devices you can run a test on please
Gareth_L
