on 10-01-2022 20:01
Ordered 1gig service middle of last week. Hub 4 arrived Saturday, quick and easy switch out of hub 3, hub 4 in. Up and running inside 15 minutes after auto software update.
Laptop connected directly into ethernet port 4 to log in 192.168.01 to change to modem only mode. I had a quick check at the logs and could see the 120000 and 5500 had been loaded. All good.
Ookla speedtest to several different servers over the last two days shows no download speed greater than 300mb with an upload of 35mb. Slower than the old hub 3 500mb service.
Rebooted hub - no change. Reset hub - no change.
Cannot now connect to 192.168.0.1 or 192.168.100.1 (cannot be reached, took too long to respond)
Am I missing something obvious or a duff hub that needs replaced?
Mur
on 29-04-2022 14:09
I’m having the same issue, slower Wi-Fi speeds with new hub 4 on volt 1 gig service than I was getting with volt m600 with hub 3?
is there any solution to this issue as yet?
Dave
on 01-05-2022 14:37
Hi @Dave-wh,
Welcome back to our Community Forums! I'm very sorry to hear that you're experiencing some WiFi speed issues with your new Hub 4. If you're experiencing an ongoing issue, we would prefer for you to create your own thread, as each issue is individual and can differ slightly, meaning that some resolutions presented may not necessarily resolve your ongoing problem. However, I will be more than happy to look into this further for you and assist as much as I can.
Can you please confirm if you're experiencing speed issues on a wired connection as well, or is this a WiFi only issue?
Have you been able to take a look at our Speed Up page to see if there's anything there that can assist with this problem?
Please let us know how you get on.
Thank you.
on 01-05-2022 16:43
Page you link doesn’t work for me. I click to test connection and it comes up with below, see screen shot. Yes with the wired too. I used a 12 month old dell laptop i5 using the network lead virgin supplied to go from router to tv box, very slow and blocky and less speed than my Wi-Fi?
on 03-05-2022 17:12
Hi Dave-wh
Thank you for getting back to us.
We are sorry that the link does not connect you to the correct page. Can you please try here instead?
From here we have the ability to run a live check on the service and after doing this today I can confirm there have been no issues with the equipment detected and all signal and power levels appear to be running within specification.
How have things been since your last post to us?
on 03-05-2022 17:33
Thanks Nat,
clicked on the new link and got this?
on 05-05-2022 15:12
The Wi-Fi is hitting 400 - 450 with the hub 4. On the day I was upgraded to the volt gig1 service I still had the hub 3 set up whilst I waited for hub 4 to be delivered. I was getting 580 - 63( looking at ookla speed test results page from that day. I know over 400 on the Wi-Fi is good, but my iPhone 13 can do 833 on the Wi-Fi. And I still don’t know why the hub 4 is slower the the hub 3 with the same set up, same positioning and phone etc sat on my couch 3 feet away from the hub. I’ve sent the hub 3 back as well in the hub 4 box as per instructions.
on 08-05-2022 10:39
In terms of the connection - have you run into any issues/problems just to confirm?
Is it solely that the speed is different than what it was with the hub3? I just want to make sure that there are not any issues that could be in the way.
Cheers,
Ryan.
on 08-05-2022 15:20
no there are no other issues. Just that the Wi-Fi speed remains lower on hub 4 than hub 3 to be fair.
on 08-05-2022 20:36
Bit of an update. Today my Wi-Fi speed appears to have increased with the hub 4 to match the hub 3 speeds. Currently getting around 550 speed downloads and 52 speed uploads on the Wi-Fi.
on 11-05-2022 09:11
I'm so sorry to hear your speeds are effected @Dave-wh I have checked on our side and I can see that everything is still in spec and working as we would expect.
Can you post your Hub status and logs?
How to do this;
• Copy/paste the data from each of the tabs as text into a 'REPLY' as opposed to 'QUICK REPLY'. Please do not include your MAC address.
Also, set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts etc
Give it a while to gather data and then click 'Share Live graph' and paste the 'Direct Link' into the forum.
