  • 76
  • 9
dazlicous
My power levels
Hi all
how does my power levels look connection speed is fine but can be a little laggy while gaming
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
12987500002.740256 qam21
21387500001.738256 qam1
31467500001.740256 qam2
41547500001.740256 qam3
51627500001.540256 qam4
61707500001.740256 qam5
71787500001.740256 qam6
8186750000240256 qam7
91947500002.240256 qam8
102027500002.240256 qam9
112107500002.240256 qam10
122187500002.240256 qam11
132267500002.240256 qam12
142347500002.240256 qam13
152427500002.240256 qam14
162507500002.240256 qam15
172587500002.238256 qam16
182667500002.440256 qam17
192747500002.240256 qam18
202827500002.440256 qam19
212907500002.540256 qam20
223067500002.940256 qam22
23314750000340256 qam23
243227500003.240256 qam24
1Locked40.33156490
2Locked38.9140961228
3Locked40.3131362292
4Locked40.3118421270
5Locked40.9106361820
6Locked40.38311739
7Locked40.347441326
8Locked40.91821681
9Locked40.320051100
10Locked40.343444674
11Locked40.35120943
12Locked40.359091640
13Locked40.365411185
14Locked40.364461354
15Locked40.36451794
16Locked40.36606855
17Locked40.360851965
18Locked40.360051031
19Locked40.954041856
20Locked40.34924515
21Locked40.339283857
22Locked40.31947937
23Locked40.39121499
24Locked40.911921784
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1461999914.05512016 qam12
2536999884.2512016 qam13
3394000174.05512016 qam11
4325999914.05512016 qam10
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
Thx
  • 3.62K
  • 49
  • 808
CarlTSpeak
Wise owl
Re: My power levels
VM's network assurance team need to check out your area. The upstreams are all 16QAM, I doubt they should be, and you have uncorrectable FEC errors on downstreams. There is something up.
  • 622
  • 26
  • 37
Re: My power levels
Hi dazlicous,
Have you contacted our team in regards to this issue?
I can attempt to look into this for you. If you look out for the purple envelope in the top right hand corner you'll see a PM from me.
David_Bn
  • 76
  • 9
dazlicous
Re: My power levels
No pm so far and I haven’t contact VM yet buddy
