on 10-02-2022 08:39
My package is M350 but speedtest.net says DL 89 UL 36.59
on 10-02-2022 10:22
How are you testing? Wired or Wifi? VM do not guarantee wifi speeds. Tests should be done wired direct to the Hub, with a good Cat 6a cable and a gigabit capable device.
However, please post your power levels and network log from the Hub. Also setup a BQM to monitor and record your circuit. www.thinkbroadband.com/ping
Once done we can comment.
on 13-02-2022 11:26
Hi JAT247,
Thanks for posting, and welcome to our community 🙂
Sorry to see you're experiencing some slow speeds.
If you can provide the information has asked for, this will help us diagnose any potential issues.
Alex_Rm
