My 350Mb connection is throttled to 10Mb
ProTofik
I have been Virgin Media (and NTL) customer for the past 12 years. Starting with 2Mb/s connection, I went through multiple upgrades, currently at 350Mb/s.
In the past weeks or maybe months, I have noticed that as soon as I turn torrenting on any computer or server in my house on, the WAN download connection drops to 10Mb/s flat on every device in the house (total). On top of that, I experience massive, 25% packet drops (tested by ping -t 1.1.1.1 and 8.8.8.8). Turn torrent off, and bam, problem solved.
My SuperHub 3 is setup in modem mode. My edge firewall is virtualized pfSense 2.4.4 and VLAN routing is done on Cisco 3560CX. Pretty basic setup that works fine.
Has Virgin Media introduced some sort of policy recently that throttles customer's connection down to make it feel like 2007 again for torrenting, or is my SuperHub 3 modem acting up?
Paying over £50 for 10Mb connection does not seem like a good deal for me any more. There are unthrottled 70/20 options out there for half the price.
151 REPLIES 151
I've tried to say invest in a VPN because the odds are you will get caught,the copyright letters are frequent this year and the heavy downloading puts you at risk,enough said
I've no idea why the speed gets so low yes it does seem like a throttle situation that's why I suggested try smaller amounts for a week see if you can maintain the download speed downloading less
Good luck maybe it is a faulty hub3
ravenstar68
@ProTofik wrote:
I get this, but it still doesn't explain why it is only torrent traffic and nothing else that causes the 10Mb/s drop.
Are you limiting your upload rate when torrenting?
Be aware that most torrent clients will use all the upstream bandwidth by default.  This has a knock on effect in limiting the downstream quite drastically due to the way DOCSIS actually works.
Tim
ProTofik
Here is another interesting thing.
I have noticed that broadband alternates between 1MB/s and 45MB/s exactly every 60 seconds.
So I did this:
This resolved the issue for about 10 minutes, after which is started alternating again, but this with being 3min good and 30s bad. After another 15 mins, it went down to 60s good and 60s bad.
It is only 23C in my room so again, doesn't make sense, but change of behaviour like this caused by extra airflow again points at something being wrong with the hub...
Yes, I know, 350Mb down, 20Mb up, but not necessarily at the same time. I always limit the client to half the available download speed, so in this case 10Mb/s (~1MB/s)
The torrents I am testing on, no one downloads them off me at the same time.
I can be uploading at full speed all the time when I'm not downloading and it has no noticeable effect on my broadband download speed.
Can you remove the attenuator? Bear with me if it seems silly, but my experience of dealing with difficult problems is to rule out as many possibilities as you can.
Hub 5, TP-Link TL-SG108S 8-port gigabit switch, 360
My Broadband Ping - Roger's VM hub 5 broadband connection
Well the engineer replaced it today after fixing noise on the line. If I remember right, it changed from 6db to 15db.
I will try it tomorrow.
So I did this:
Maybe the hub is over heating? but I think all hub 3 have this issue due to no heatsink on the CPU.
The fan would also indirectly  cooling the equipment below. Could they be the problem rather than the hub
Don't think I've seen a BQM in the thread - probably worth setting one up and posting results
ravenstar68
I would like to point out that to the best of my knowledge VM techs are supposed to be avoiding the use of attenuators where possible anyway.  Normally they should be using the correct tap point at the street cab so that the power levels fall with in the ideal range by the time it gets to your house.  (different tap points have different attenuations to support how close the houses are to the street cab itself).
Tim
Mia_C
Hi, ProTofik,
Thank you for updating us here in the Virgin Media Community forum.
Your updates can surely help if any of our members here would encounter the same issue.
I see that you have another visit scheduled today , Monday.
I just want to check on you and if you can update us on that appointment, too.
We're hoping that the torrenting issue you have will now be resolved.
Keep us posted. Thanks.
Mia_C
