piperazine
  • 53
Message 1 of 7
Massive Signal Drop BN Help!
Hello,
Woke up this morning, and we have seemed to have had a massive signal drop overnight. Two of our virgin TV's are not displaying some channels, and our router has had a -15dBmV drop giving us barely any speed and very dodgy connections.
Gonna give Virgin a call this morning, but thought I'd post here as I've had more help from here in the past.
Hopefully this will get sorted quick, the kids need the internet for school.
1298750000-1828256 qam21
2218750000-1729256 qam11
3226750000-1729256 qam12
4234750000-17.229256 qam13
5242750000-17.329256 qam14
6250750000-17.329256 qam15
7258750000-17.828256 qam16
8266750000-17.928256 qam17
9274750000-1828256 qam18
10282750000-18.428256 qam19
11290750000-1828256 qam20
12306750000-1828256 qam22
13314750000-18.328256 qam23
14322750000-18.328256 qam24
15402750000-19.727256 qam25
16410750000-19.527256 qam26
17418750000-19.427256 qam27
18426750000-19.227256 qam28
19434750000-19.227256 qam29
20442750000-1927256 qam30
21450750000-1927256 qam31
22458750000-19.327256 qam32
23466750000-19.527256 qam33
24474750000-19.727256 qam34
1537000004.975512064 qam1
2462000004.8512064 qam2
3394000004.7512064 qam3
4326000004.6512064 qam4
DJ_Shadow1966
  • 6.65K
  • 1.28K
  • 1.81K
Message 2 of 7
Re: Massive Signal Drop BN Help!
Hello
That is the lowest I have seen for sometime.
I would go around  and make sure that all coaxial connections to all VM equipment are finger tight, then power of hub for 30 secs and back on, if those signal levels are still below -6 then an engineer will be needed.
Regards Mike
piperazine
  • 53
Message 3 of 7
Hello,
Thanks for the reply.
No devices have been moved, all connections seem OK, and rebooting the router did not work. Could be one of the splitters has failed? Internal break in a cable? Problem at the cab?
Will wait to hear what Virgin say on the phone.
gary_dexter
  • 29.18K
  • 1.79K
  • 3.82K
Message 4 of 7
Is there an attenuator fitted to the back of the hub?
piperazine
  • 53
Message 5 of 7
No attenuator.
The Hub is at the rear of the house, from the front of the house it goes through 3 splitters to get there (one powered). We have also got four Virgin TV's (three of which are not displaying channels correctly). The only telly that is working is the one that comes directly off the first splitter, although the diagnostics info page for that Tivo box says signal is only 80%.
Just got through to Virgin and we've got an engineer booked.
piperazine
  • 53
Message 6 of 7
Just to update.....
Just had a text from Virgin saying that they are putting our engineer visit on hold whilst they investigate a network issue.
So I'm guessing that this problem could be further upstream somewhere?
gary_dexter
  • 29.18K
  • 1.79K
  • 3.82K
Message 7 of 7
Yes could be.
They suspend engineer visits if there’s a local/network issue as there’s nothing a home visit can do to cure it.
