on 23-01-2022 18:54
Hi all this is my first post here so hopefully I am providing useful information. I am on a Virgin Media M500 package and I'm seeing large variations in the speed of my service. According to fast.com I had 14 Mbps last night, 510Mbps this morning and I'm back down to 20 Mbps as I type this message. My upload speed seems less varied around 30Mbps.
Note I am not changing any of my configuration, so I would think the variation in speed is most likely coming from outside my home.
My setup is:
I've tested speed using fast.com, thinkbroadband, samknows and the AmpliFi's built-in speed tests. The built-in test rules out any fluctuations caused by WiFi.
Accessing Virgin's own check https://care.virginmedia.com/care/check-services gives me the error "Looks like you’re having trouble connecting to the Hub". I am wondering if that's because it's in modem mode.
I've just signed up to thinkbroadband's quality monitor as attached.
Also attached are my latest superhub stats. Does anyone have any suggestions for what I could look at?
Many thanks.
1 | 202750000 | 8.3 | 40 | 256 qam | 9 |
2 | 138750000 | 9 | 32 | 256 qam | 1 |
3 | 146750000 | 8.6 | 31 | 256 qam | 2 |
4 | 154750000 | 8.6 | 36 | 256 qam | 3 |
5 | 162750000 | 8.9 | 40 | 256 qam | 4 |
6 | 170750000 | 9.1 | 40 | 256 qam | 5 |
7 | 178750000 | 9 | 40 | 256 qam | 6 |
8 | 186750000 | 8.8 | 40 | 256 qam | 7 |
9 | 194750000 | 8.5 | 40 | 256 qam | 8 |
10 | 210750000 | 8.1 | 40 | 256 qam | 10 |
11 | 218750000 | 8 | 40 | 256 qam | 11 |
12 | 226750000 | 7.4 | 40 | 256 qam | 12 |
13 | 234750000 | 7.3 | 40 | 256 qam | 13 |
14 | 242750000 | 7.3 | 40 | 256 qam | 14 |
15 | 250750000 | 7.4 | 40 | 256 qam | 15 |
16 | 258750000 | 7.1 | 40 | 256 qam | 16 |
17 | 266750000 | 7.5 | 40 | 256 qam | 17 |
18 | 274750000 | 8.1 | 40 | 256 qam | 18 |
19 | 282750000 | 8.4 | 40 | 256 qam | 19 |
20 | 290750000 | 8.5 | 40 | 256 qam | 20 |
21 | 298750000 | 8.1 | 40 | 256 qam | 21 |
22 | 306750000 | 7.6 | 40 | 256 qam | 22 |
23 | 314750000 | 7.5 | 40 | 256 qam | 23 |
24 | 322750000 | 7.5 | 40 | 256 qam | 24 |
1 | Locked | 40.3 | 1385 | 1352 |
2 | Locked | 32.2 | 21958602 | 282299227 |
3 | Locked | 31.6 | 12709168 | 291614625 |
4 | Locked | 36.6 | 31126 | 309 |
5 | Locked | 40.3 | 1241 | 23 |
6 | Locked | 40.3 | 1863 | 1958 |
7 | Locked | 40.3 | 1790 | 1911 |
8 | Locked | 40.3 | 1899 | 793 |
9 | Locked | 40.3 | 1796 | 916 |
10 | Locked | 40.3 | 1306 | 40 |
11 | Locked | 40.3 | 1108 | 29 |
12 | Locked | 40.3 | 129 | 0 |
13 | Locked | 40.3 | 28 | 0 |
14 | Locked | 40.3 | 8 | 0 |
15 | Locked | 40.3 | 27 | 0 |
16 | Locked | 40.3 | 7 | 0 |
17 | Locked | 40.3 | 16 | 0 |
18 | Locked | 40.9 | 5 | 0 |
19 | Locked | 40.3 | 8 | 0 |
20 | Locked | 40.3 | 12 | 0 |
21 | Locked | 40.3 | 7 | 0 |
22 | Locked | 40.3 | 19 | 0 |
23 | Locked | 40.3 | 16 | 0 |
24 | Locked | 40.3 | 7 | 0 |
on 25-01-2022 08:19
You need a technician to sort it.
Hopefully a forum staff member will pick this up and help.
on 29-01-2022 12:04
Hi michrome,
Thanks for your post and I'm sorry to hear about the issues you have been having with your broadband. I'm happy to take a look in to things but I've been unable to locate you on our systems using your forum credentials. I will need to confirm some information with you in order for me to proceed with checks.
I have sent you a private message regarding this and will investigate further once I receive your reply. Just click on the little plum envelope at the top right-hand side of the page to access your inbox.
