smithmg7
  • 9
Message 1 of 9
M200 slow upload of 1.5 mb and dropping out
My hub keeps dropping connection and the upload speed is 1.5mb download varies between 20 and 150mb, was getting a raft of t3 timeouts but after rebooting hub a number of times this has gone away , Hub refuses to go back to factory settings though.
here is my bqm
https://www.thinkbroadband.com/broadband/monitoring/quality/share/390cc25fc6a1a375448a3baca4eca03f3c...
Upstream looks a little strange though
13940030445.8512016 qam2
22579973945.8512032 qam4
33259981145.8512016 qam3
44619975745.8512064 qam1
speed test done whilst connected to hub
24-01-2021 21:45:17 (GMT)40.1 Mbps2.8 MbpsVirgin Media view result
21-01-2021 22:16:30 (GMT)44.7 Mbps1.0 MbpsVirgin Media view result
20-01-2021 21:10:13 (GMT)84.1 Mbps2.1 MbpsVirgin Media view result
19-01-2021 20:04:26 (GMT)74.5 Mbps2.7 MbpsVirgin Media view result
19-01-2021 20:02:55 (GMT)77.4 Mbps0.8 MbpsVirgin Media view result
19-01-2021 19:59:58 (GMT)74.0 Mbps1.5 MbpsVirgin Media
tehwolf
  • 1.57K
  • 254
  • 378
Superfast
Message 2 of 9
Re: M200 slow upload of 1.5 mb and dropping out
All four upstream channels should be at 64qam, 3/4 of yours are not and are almost certainly impacting your upload speeds..
post the full tables from downstream, upstream and network log, someone who understands it all will, I’m sure, comment on potential causes.
smithmg7
  • 9
Message 3 of 9
Item Status Comments
331000000
Locked
Ranged Upstream Channel (Hz)
39399421
Locked
Provisioning State
Online
13310000002.738256 qam25
22190000002.938256 qam11
3227000000338256 qam12
42350000002.938256 qam13
52430000002.538256 qam14
62510000002.538256 qam15
72590000002.538256 qam16
8267000000238256 qam17
92750000002.238256 qam18
102830000002.238256 qam19
11291000000238256 qam20
122990000002.438256 qam21
133070000002.538256 qam22
143150000002.538256 qam23
153230000002.538256 qam24
163710000002.738256 qam26
173790000002.538256 qam27
183870000002.538256 qam28
193950000002.938256 qam29
204030000002.938256 qam30
21411000000338256 qam31
22419000000338256 qam32
234270000002.938256 qam33
244350000002.538256 qam34
1Locked38.9790
2Locked38.6960
3Locked38.6750
4Locked38.9890
5Locked38.61570
6Locked38.91120
7Locked38.61120
8Locked38.91770
9Locked38.91630
10Locked38.91580
11Locked38.91670
12Locked38.62140
13Locked38.91630
14Locked38.61650
15Locked38.61290
16Locked38.9760
17Locked38.91040
18Locked38.9880
19Locked38.9760
20Locked38.6760
21Locked38.9540
22Locked38.9940
23Locked38.9500
24Locked38.9870
13939942146512016 qam2
22579999245.8512032 qam4
33260012745.8512016 qam3
44620005945.8512064 qam1
3ATDMA0000
4ATDMA0000
Rest in next message
smithmg7
  • 9
Message 4 of 9
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060+voc-b.cm
SFID393462
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID393461
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
23/01/2021 21:08:56noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/01/2021 23:25:32ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/01/2021 23:25:30ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/01/2021 20:17:19noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/01/2021 13:43:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/01/2021 20:36:34noticeNOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/01/2021 10:06:6ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 09:29:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 11:42:45noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 05:36:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 22:06:6ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 10:22:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 02:25:50ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/01/2021 00:02:49noticeSW download Successful - Via NMS
09/01/2021 00:01:0noticeSW Download INIT - Via NMS
08/01/2021 23:21:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 04:46:18ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/2021 23:42:43noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Hope that Helps , I'm struggling to post my Church Services online at the moment.
1hr 50 for a 20 minute video and 3hrs for a 40 minute video
Any help would be gratefully received
tehwolf
  • 1.57K
  • 254
  • 378
Superfast
Message 5 of 9
Im no expert on the docsis side off things but I believe your upstream power should be below 40 - it’s too high on all channels and suspect that you’ll need an engineer to put it right.
smithmg7
  • 9
Message 6 of 9
as if by a miracle now it has stopped raining / snowing my uploads now increased to 20mb and the modulation has gone back to 64 quam although i now get the occasional T3 timeout
13940000045.8512064 qam2
22580000045.5512064 qam4
33260000045.5512064 qam3
44620000045.5512064 qam1
smithmg7
  • 9
Message 7 of 9
and as if by magic it's raining and download speed has dropped and router now shows the same as before with Mixed modulations
13940006545.8512016 qam2
22580004845.5512064 qam4
33259983045.5512016 qam3
carl_pearce
  • 4.73K
  • 403
  • 706
Superstar
Message 8 of 9
I wonder if your local cabinet is open to the elements?
Do you have any neighbours with VM you could check with?
smithmg7
  • 9
Message 9 of 9
Carl I don't know but wouldn't be surprised most of them around here are held together with tape ?, what I want is for virgin to accept that there is an issue whether that issue id the weather or contention.
either as I am not getting the upload performance I need to work , and trying to get the helpdesk to answer or raise a fault is bad enough as all I get is cant see anything our end, that's not what BQM is showing and not what the Hub is showing,
Having Mixed Modulation types is not going to work it should be 64qam across the board not 16 and 64 and like last week 8 16 and 64.
come on Virgin do something
