Boydy1
M100 hub
I’ve recently upgraded to m100 but I still have the same hub from years ago. And recently my speeds have dropped significantly. Is there any connection between having a old hub and slow speeds
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: M100 hub
At 100Mbs the Hub will have no bearing on the speed you get unless it is ancient or broken.
Which Hub do you have ?
  • 22.36K
  • 2.4K
  • 3.99K
Re: M100 hub
What Hub model is it - printed on its sticker. If its an old Superhub1/2/2ac it can be upgraded for free. The SH1 should definitely be swapped - SH2's - debatable?
Are you talking about wifi speeds or those on an ethernet cable connected device?
