Deadrebirth
  • 51
Message 1 of 28
Low upload speeds
Hi there,
Over the last few days I've noticed my upload speed seems to be dropping from 21 mbps to around 2-3, which is making doing the gaming and streaming that I enjoy rather difficult due to this. Tho it seems I'm not the only one with the issue i'll throw a post in just incase there isn't one for my area (service status + test seems to think everythings fine).
Below is the BQM monitor i set up yesterday and the info from my router I believe you need, let me know if theres anything else you need.
(Monitor + network log in following post due to character limit)
1394000004.35512064 qam4
2602998934.475512064 qam1
3536999514.45512064 qam2
4462000694.4512064 qam3
3ATDMA0000
4ATDMA0000
15070000001.737256 qam13
2411000000236256 qam1
34190000001.937256 qam2
44270000002.237256 qam3
54350000002.537256 qam4
64430000002.537256 qam5
7451000000237256 qam6
84590000001.937256 qam7
94670000001.537256 qam8
104750000001.737256 qam9
11483000000237256 qam10
124910000002.237256 qam11
13499000000237256 qam12
145150000001.737256 qam14
15523000000237256 qam15
165310000002.438256 qam16
175390000002.237256 qam17
185470000001.737256 qam18
195550000001.538256 qam19
205630000001.738256 qam20
215710000002.237256 qam21
225790000002.738256 qam22
235870000002.538256 qam23
245950000001.938256 qam24
1Locked37.6720
2Locked36.6510
3Locked37.3380
4Locked37.6210
5Locked37.6370
6Locked37.3400
7Locked37.6431
8Locked37.6450
9Locked37.6490
10Locked37.6730
11Locked37.3620
12Locked37.6650
13Locked37.3550
14Locked37.6860
15Locked37.6930
16Locked38.6820
17Locked37.6980
18Locked37.61090
19Locked38.6730
20Locked38.610240
21Locked37.61360
22Locked38.61250
23Locked38.61540
24Locked38.61330
Deadrebirth
  • 51
Message 2 of 28
Re: Low upload speeds
15/06/2020 15:35:59criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2020 15:21:53ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2020 15:11:19ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2020 02:58:6criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/06/2020 15:34:20ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/06/2020 22:06:10ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/06/2020 11:34:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/06/2020 10:13:21ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/06/2020 06:45:14ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/06/2020 05:47:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/06/2020 20:21:4ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/06/2020 10:32:1criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/06/2020 06:28:50ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Heres the network log but I am having alot of trouble trying to post the BQM graph (Hoping the link below works?)
https://www.thinkbroadband.com/broadband/monitoring/quality/share/b95ce2464ff36354cf779b5715975fe6f80dc7a6
Chris_W1
  • 4.06K
  • 185
  • 255
Message 3 of 28
HI Deadrebirth, we will send you a private message. ^Chris
John_GS
  • 9.18K
  • 494
  • 831
Message 4 of 28
Thanks for sending me a PM Deadrebirth,
There's no issues showing on the account. Can you do a wired speedtest for me non-console, at speedtest.net using only 1 device connected to the internet?
Kind regards,
John_GS
Deadrebirth
  • 51
Message 5 of 28
Hi there John,
So the last week or so the issues seems to have disappeared for the most part (not sure what the issue was really aside from maybe the thunderstorm). It was primarily over the few days before making the original post that there seemed to be consistent issues. speedtests have pretty much been running as normal of late (see below). If it reoccurs I'll let you know.
Lisa_CC
  • 4.11K
  • 240
  • 490
Moderator
Moderator
Message 6 of 28
Happy to hear it's working as expected Deadrebirth and do let us know if you have anymore issues with it.
Lisa
Deadrebirth
  • 51
Message 7 of 28
Hello again,
Unfortunately the issues still seem to persist, it would seem that it occurs most frequent from around 3:30pm each day.
https://www.thinkbroadband.com/speedtest/1593787086184436055
Speedtest.net seems to say its fine yet this one appears to indicate otherwise. Not sure if this helps - if more info is needed let me know.
Zoie_P
  • 2.91K
  • 137
  • 235
Message 8 of 28
Hi Deadrebirth,
Thank you for your post 🙂 I am sorry you are having some issues, I have done some remote checks and there are some issues and we need to get a tech out, I will pop you over a private message asking for some details and we can get this sorted for you
Zoie
Zoie_P
  • 2.91K
  • 137
  • 235
Message 9 of 28
Hi Deadrebirth,
Please let us know how your tech visit goes, and then how your service is thereafter 🙂
Zoie
Deadrebirth
  • 51
Message 10 of 28
Will do, thanks again for the help.
