Low upload G75 area
ronnieburns
Having trouble with low upload speeds.
Downloads are over 200 meg but upload is only around 3 or 4.  It's usually around 20 meg. This is causing issues.
Postcode is G75 8UT.  Service checker says no issues but it's been bad for 2 days now.
I've done a few hard resets, checked cables etc, all the usual stuff. Tried wired and wireless. Using hub 3.  I've noticed a hub restart takes a lot longer these days and I just had an email a few days ago saying virgin have tweaked settings to make things better.  Seems to have made it worse as I had no problems before.
Any advice on a fix VM?
28 REPLIES 28
ronnieburns
Hi, everything was great but the issue has returned.
The engineer done a pinhole reset and replaced a connector outside somewhere and speeds were fine until today.  He did mention that the signal was close to out of spec but not actually out. Tonight the VM test says the same thing, interference on the cabling.   So I'm getting kicked from things for low speed again.
Natalie_L
Thank you for letting us know ronnieburns.
As some changes have been made since you last posted your Hub stats, are you able to provide these again for us?
Also a link to a live BQM if possible please?
Thank you
Nat
ronnieburns
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1331000000240256 qam25
22670000001.740256 qam17
32750000001.940256 qam18
42830000001.940256 qam19
5291000000240256 qam20
62990000002.240256 qam21
7307000000240256 qam22
8315000000240256 qam23
93230000002.240256 qam24
103390000001.940256 qam26
11347000000240256 qam27
123550000001.940256 qam28
13363000000240256 qam29
143710000002.540256 qam30
153790000002.440256 qam31
163870000001.940256 qam32
17395000000240256 qam33
184030000001.740256 qam34
194110000001.540256 qam35
204190000001.540256 qam36
214270000001.440256 qam37
224350000001.540256 qam38
234430000001.240256 qam39
24451000000140256 qam40
1Locked40.33933916631662
2Locked40.389094203198394
3Locked40.399658143174830
4Locked40.97777415844446
5Locked40.37877972643385
6Locked40.38354642671325
7Locked40.34172767364045
8Locked40.97000990489373
9Locked40.95748317960105
10Locked40.35642781293280
11Locked40.33340104263753
12Locked40.33312282258863
13Locked40.35428799243332
14Locked40.93297902513387
15Locked40.32943443641948
16Locked40.33135814236333
17Locked40.3382079157460
18Locked40.3776251141399
19Locked40.3171751391266
20Locked40.31529642103418
21Locked40.396979265423
22Locked40.375725457012
23Locked40.323739862237
24Locked40.326269742320
14620000051512064 qam3
23260000049.5512064 qam5
33940000051512064 qam4
45370000051512064 qam2
1ATDMA0020
2ATDMA0040
3ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
4ncxv9873254k;fg87dsfd;kf
SFID608
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID607
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
ronnieburns
Router status
Network LogTime Priority Description
04/10/2021 00:17:1noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2021 09:46:17noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2021 09:46:17ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/10/2021 07:20:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/10/2021 00:36:55Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/10/2021 00:36:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2021 12:53:54Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2021 12:53:5criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2021 12:15:11Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2021 12:15:5criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2021 11:50:34Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2021 10:16:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2021 04:09:52Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2021 04:09:37criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2021 00:19:34Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/10/2021 00:19:34criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/09/2021 22:43:4Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/09/2021 22:43:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/09/2021 22:26:6Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/09/2021 22:26:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Good morning ronnieburns
Thanks for posting. My apologies for the upload speed issues.
I've ran a system check today and can see that until Monday, you had an SNR issue (signal to noise ratio) - this would have been the cause of it.
This has now been resolved - has your upload speed returned?
Let me know if you need further assistance.
Best,
John_GS
Hi again
 It seems ok now. I'll keep an eye on it though.
Hayley_S
Hello @ronnieburns,
Thank you for letting us know, I hope all stays okay for you.
Many thanks,
Hayley
