on 27-01-2022 11:47
Paying for 200mb & just ran a test showing 71mbps?????
on 02-02-2022 15:29
HI WelshDeano,
Thank you for your post and welcome to forums 🙂
I am sorry to hear you are having issues with your speeds.
I can see from our systems you have not rebooted in 20 days if you could reboot to see if this helps, then run a wired speed test from speedtest.net.
If you check here, it will show you what minimum speeds you should be getting.
Zoie
