Miker604
  • 13
Message 1 of 14
Low speed unless hub restarted
I had my m500 installed yesterday. When engineer left the hub restarted on its own twice. It hasn't (that I'm aware of) since.
Last night I noticed I was only getting 50mbps download speed. I tested wirelessly and wired.
I then manually reset the router using the pin hole on the back and tested again. This time I was getting around 450mbps.
I have tested again this morning and was roughly 350mbps. Then again just now (15.15) and I'm back down to 50mbps.
I have reset the router again using the pinhole button and tested speeds again. Now around 450mbps.
I believe I may need an engineer to attend as it seems like noise may be knocking some channels off therefore losing speed?
Tags (1)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 14
Re: Low speed unless hub restarted
It can be difficult diagnosing problems without some basic information.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Can you set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the other side of the Hub, it will take a few hours to get any kind of trend showing although you can post the link straight away.
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
Miker604
  • 13
Message 3 of 14
Miker604
  • 13
Message 4 of 14
14027500002.538256 qam30
22027500003.538256 qam9
32107500003.538256 qam10
42187500003.540256 qam11
52267500003.438256 qam12
62347500003.238256 qam13
72427500003.238256 qam14
8250750000338256 qam15
92587500002.740256 qam16
102667500002.738256 qam17
112747500002.540256 qam18
122827500002.540256 qam19
132907500002.538256 qam20
142987500002.538256 qam21
153067500002.540256 qam22
163147500002.538256 qam23
173227500002.538256 qam24
183307500002.538256 qam25
193707500002.738256 qam26
20378750000338256 qam27
213867500002.540256 qam28
223947500002.540256 qam29
234107500002.738256 qam31
244187500002.538256 qam32
1Locked38.640
2Locked38.650
3Locked38.960
4Locked40.350
5Locked38.950
6Locked38.650
7Locked38.670
8Locked38.950
9Locked40.330
10Locked38.970
11Locked40.340
12Locked40.950
13Locked38.960
14Locked38.660
15Locked40.350
16Locked38.940
17Locked38.940
18Locked38.660
19Locked38.950
20Locked38.950
21Locked40.3110
22Locked40.350
23Locked38.660
24Locked38.950
Miker604
  • 13
Message 5 of 14
1537000003.218512064 qam2
2394000003.225512064 qam4
3462000073.225512064 qam3
4603000343.225512064 qam1
3ATDMA0000
4ATDMA0000
Miker604
  • 13
Message 6 of 14
22/08/2020 15:33:31noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/08/2020 05:22:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/08/2020 20:54:22noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/08/2020 20:48:24Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/08/2020 17:08:5criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/08/2020 12:29:55Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/08/2020 11:44:11noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/08/2020 11:44:11ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/08/2020 11:08:42noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/08/2020 10:49:31Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/08/2020 10:49:29noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/08/2020 10:49:29ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/08/2020 10:48:25Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/08/2020 10:48:25criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/08/2020 10:48:17Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/08/2020 10:48:17criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/08/2020 10:48:16Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/08/2020 10:48:16criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/08/2020 10:46:37Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/08/2020 10:27:51noticeSW download Successful - Via Config file
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 14
What happened at 15:30ish ?
Miker604
  • 13
Message 8 of 14
I restarted the router using pin hole to regain speeds
jhuk
  • 3K
  • 52
  • 286
Problem sorter
Message 9 of 14
Just to be sure, post the Configuration part from the above Router status.
Miker604
  • 13
Message 10 of 14
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
;kfoA,.iyewrkldJKDHSUBsgvca69
SFID484
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID483
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
