Bhatich
  • 6
Message 1 of 16
Low speed on Hub4
Upgraded to Gig1 from M350 and not getting the speeds that I was promised
Tried contacting Virgin on several occasions but no joy
Anonymous
Not applicable
Message 2 of 16
Re: Low speed on Hub4
is this a wired connection with a gigabit network card
Bhatich
  • 6
Message 3 of 16
This is a WiFi connection to my iPhone from the new Hub 4 were I was promised much higher speeds than with my previous Virgin Router
Anonymous
Not applicable
Message 4 of 16
your very very unlikey to see speeds anywhere near 1000 on wifi.
you need to test with a wired connection
Bhatich
  • 6
Message 5 of 16
No one is expecting 1000 on WiFi , but was expecting and promised more than I had on M350
and yes my device is only 2 metres from the router
Anonymous
Not applicable
Message 6 of 16
your garanteed speed is for wired connections. It doesn't apply to wifi.
you have not been promised any speed over wifi.
Anonymous
Not applicable
Message 7 of 16
what speeds does https://samknows.com/realspeed/ show?
Anonymous
Not applicable
Message 8 of 16
Which iPhone?
Each device uses different wireless standards and wireless is only as good as the worst device, either end of the connection.
Bhatich
  • 6
Message 9 of 16
Just ran a wired Speedtest to a laptop that is 2 metres from the Hub
speed was only 320 Mbps , not much difference if any from Hub 3 and the M350 package
Anonymous
Not applicable
Message 10 of 16
Which iPhone?
