Hi, I'm expeirencing a drop in bandwidth since upgrading to M500 from M350. Everytime I carry out a speed test, connect via a network cable I'm only seeing download speeds of ~100Mbps. Before the upgrade I was seeing at least double that during the day and higher speeds 300+ later on in the evening. I've tried rebooting the superHub3 and all my network equipment, as I run the superHub3 in modem mode and still no joy.
Below is my current router status, hopefully someone can shed some light on the issue and a way to resolve it.
Status:
Item Status Comments
Acquired Downstream Channel (Hz) | 323000000 | Locked |
Ranged Upstream Channel (Hz) | 32600061 | Locked |
Provisioning State | Online |
1 | 323000000 | -6.5 | 38 | 256 qam | 24 |
2 | 139000000 | -7.5 | 37 | 256 qam | 1 |
3 | 147000000 | -7.2 | 38 | 256 qam | 2 |
4 | 155000000 | -7 | 38 | 256 qam | 3 |
5 | 163000000 | -6.9 | 38 | 256 qam | 4 |
6 | 171000000 | -6.9 | 38 | 256 qam | 5 |
7 | 179000000 | -6.7 | 38 | 256 qam | 6 |
8 | 187000000 | -6.7 | 38 | 256 qam | 7 |
9 | 195000000 | -6.7 | 38 | 256 qam | 8 |
10 | 203000000 | -7 | 38 | 256 qam | 9 |
11 | 211000000 | -7 | 38 | 256 qam | 10 |
12 | 219000000 | -6.9 | 38 | 256 qam | 11 |
13 | 227000000 | -6.9 | 38 | 256 qam | 12 |
14 | 235000000 | -7 | 38 | 256 qam | 13 |
15 | 243000000 | -7 | 38 | 256 qam | 14 |
16 | 251000000 | -7 | 38 | 256 qam | 15 |
17 | 259000000 | -7 | 38 | 256 qam | 16 |
18 | 267000000 | -7.2 | 38 | 256 qam | 17 |
19 | 275000000 | -7.2 | 38 | 256 qam | 18 |
20 | 283000000 | -7.2 | 38 | 256 qam | 19 |
21 | 291000000 | -7 | 38 | 256 qam | 20 |
22 | 299000000 | -6.9 | 38 | 256 qam | 21 |
23 | 307000000 | -6.7 | 38 | 256 qam | 22 |
24 | 315000000 | -6.7 | 38 | 256 qam | 23 |
1 | Locked | 38.6 | 13 | 0 |
2 | Locked | 37.6 | 328941 | 1583732 |
3 | Locked | 38.6 | 230573 | 1021120 |
4 | Locked | 38.9 | 965235 | 774558 |
5 | Locked | 38.9 | 675677 | 1275202 |
6 | Locked | 38.6 | 406 | 0 |
7 | Locked | 38.9 | 204 | 0 |
8 | Locked | 38.6 | 140 | 0 |
9 | Locked | 38.9 | 157 | 0 |
10 | Locked | 38.9 | 473 | 0 |
11 | Locked | 38.9 | 1254 | 0 |
12 | Locked | 38.9 | 2231 | 0 |
13 | Locked | 38.6 | 2424 | 0 |
14 | Locked | 38.6 | 1477 | 0 |
15 | Locked | 38.9 | 809 | 0 |
16 | Locked | 38.9 | 173 | 0 |
17 | Locked | 38.6 | 60 | 0 |
18 | Locked | 38.9 | 21 | 0 |
19 | Locked | 38.6 | 13 | 0 |
20 | Locked | 38.9 | 15 | 0 |
21 | Locked | 38.6 | 12 | 0 |
22 | Locked | 38.6 | 19 | 0 |
23 | Locked | 38.9 | 20 | 0 |
24 | Locked | 38.6 | 14 | 0 |
