on 11-02-2022 19:27
for the past couple of days we have experienced quite a few disconnects of Broadband and TV services
On the 10/2/22 there was apparently an area issue which was apparently fixed by 18:00, but Today 11/2/22 there has been 3 further incidents of loss of service (BQM attached)
I hope this is related to an area issue and not my connection Turing to rat poop as service status check says ‘everything is fine’
all levels look ok but the BQM shows the drops as does the network logs
https://www.thinkbroadband.com/broadband/monitoring/quality/share/3d1a5a0db04296b563b6a1d706f537b82e3ceda9-11-02-2022
on 11-02-2022 19:31
Hub log below
2022 15:50:12Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;11/02/2022 15:49:10criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;11/02/2022 15:48:18Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;11/02/2022 15:48:13criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;11/02/2022 15:48:13Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;11/02/2022 15:48:13criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;11/02/2022 15:48:12Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;11/02/2022 14:37:39criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;11/02/2022 14:37:15criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;11/02/2022 14:37:14Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;11/02/2022 14:37:14criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;11/02/2022 14:36:46Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;11/02/2022 08:13:35Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;11/02/2022 08:12:36criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;11/02/2022 08:11:50Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;11/02/2022 08:11:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;11/02/2022 08:11:45criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;11/02/2022 08:11:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;11/02/2022 08:11:45criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
on 11-02-2022 19:35
on 11-02-2022 20:07
And it’s all gone off again 🤬
on 11-02-2022 20:14
Tried the freephone service checker…. Nothing wrong…..
now it’s back again 🙄
that’s the 4th time in the space of 12 hours
on 14-02-2022 13:46
Hi @jka94036,
Welcome back to our Community Forums! Thank you for your post, and I'm very sorry to hear that you're experiencing some ongoing intermittent issues with your broadband and your TV services. I can understand how frustrating this can be.
I was able to run some checks on our systems, and at the moment, I cannot see any area issues that could be impacting your services at the moment, and cannot see any power level issues with your services.
Would you be able to set up a BQM chart and share a live link to your connection, so we can see when those disconnections are occurring and see what we can do to help.
Thank you.
on 14-02-2022 14:01
I did include a BQM link in my first post when the issues occurred , but have included a live link as requested below.
The days in question are the 10,11, 12 & 13th Feb
I have had previous drops but these seemed to have occurred during the early hours so put these down to ‘maintenance’
Since the brief disconnect on the 13th am things have been ok
https://www.thinkbroadband.com/broadband/monitoring/quality/share/aacc90f1c66eb9d95a1ac9e88b5e41be157fd94a
on 15-02-2022 20:56
Had another disconnect of TV and Broadband tonight (15/2/22) only for a few seconds this time but nonetheless very annoying this keeps happening recently
I can see all hub stats are fine and live BQM is linked in previous post, but feel this is either a cabinet issue or very local network issue.
One question I have is do the isolators deteriorate over time as the ones (2) I have must be +20 years old? (Grabbing at straws here)
Network log as follows
15/02/2022 20:31:55 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/02/2022 20:31:9 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/02/2022 20:31:6 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/02/2022 20:31:5 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/02/2022 20:31:5 | Warning! | RCS |
on 16-02-2022 09:27
This is getting quite annoying now, yes I know it’s 03:40 when this latest disconnect occurred but this shouldn’t be happening quite so often
16/02/2022 03:40:4 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/02/2022 03:39:19 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/02/2022 03:37:18 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/02/2022 03:36:37 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/02/2022 03:36:33 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/02/2022 03:36:32 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/02/2022 03:36:32 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/02/2022 00:39:55 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/02/2022 20:31:5 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/02/2022 11:05:15 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/02/2022 10:57:52 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/02/2022 10:57:9 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/02/2022 10:57:5 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/02/2022 10:57:4 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 18-02-2022 09:42
Hi @jka94036, thanks for your reply and I'm sorry you've still been having problems.
It looks like there was an area outage recently, which has now been resolved and this may have affected your services.
Can you please try to reboot your Hub now, and see if things improve for you going forwards?
Many thanks
