@Nupzyo wrote:
Hi there, so...a week has gone by from having M500 fitted along with the rest of VMs top package and i have been monitoring the speeds.
The speeds don't read very well at all, average of 175mb via WiFi no greater than 218mb.
Etherner speeds are even worse, never reaches over 100mb.
I have done a small amount of digging and came across my Link speed/transmit settings via network properties on the laptop.
They read as follows:
Ethernet: Recieve/Transmit 100/100mbps
Wifi: Recieve/Transmit 200/200mbps.
These figures mirror what speeds I am currently getting. Is there something wrong here, am I being set up on a lower M package but paying for M500 or what?
Thanks for reading,
Nick.
Firstly, you can check what speed your modem is configured for by going to the web page and looking at the Configuration tab -> Primary Downstream Service Flow -> Max traffic rate.
Regarding your wired speeds, looks like your link is negotiated at 100Mb/s. Is the adapter 1Gb/s capable?
On the wireless side depending on the wireless adapter in the laptop that could be the best you can get. Can you post the adapter device ID?
