mattcharlton
Less than 0.5 downstream
Morning all,
Really struggling working from home today - usually pulling anything from 100mbps to 360mbps on speedtest (depending on which device and where I am in the house) but my whole connection seems pretty much dead in the water this morning.
Speedtest.net showing less than half a meg down, upstream showing between 10-15mbps so that's something but usually shows more like 30mbps.
Service status is green, equipment 'test' says no problems.  Anyone else having issues in BD14 / Area Ref 14?
Rebooted both my hub (running in modem mode) and my wifi equipment to no avail.  Have adjusted DNS to check that - no change.
Wife says it was like this during the day yesterday too, was fine in the evening when I got home.
Hopefully someone else is having problems/there's a known issue.
mattcharlton
Re: Less than 0.5 downstream
These Pre RS errors look a little worrying:
1Locked36.34790
2Locked37.35680
3Locked37.66010
4Locked36.65760
5Locked37.35880
6Locked37.65680
7Locked36.65880
8Locked36.65900
9Locked36.65730
10Locked36.65110
11Locked36.34990
12Locked36.33830
13Locked36.32600
14Locked36.32720
15Locked35.52790
16Locked35.71880
17Locked35.72170
18Locked35.71970
19Locked35.76850
20Locked36.34680
21Locked35.513530
22Locked35.513960
23Locked35.713560
24Locked36.36710
1267000000-9.536256 qam17
2187000000-6.737256 qam7
3195000000-737256 qam8
4203000000-7.536256 qam9
5211000000-7.737256 qam10
6219000000-7.537256 qam11
7227000000-836256 qam12
8235000000-8.236256 qam13
9243000000-8.536256 qam14
10251000000-8.736256 qam15
11259000000-9.236256 qam16
12275000000-9.536256 qam18
13283000000-9.536256 qam19
14291000000-9.736256 qam20
15299000000-9.735256 qam21
16307000000-9.735256 qam22
17315000000-9.535256 qam23
18323000000-9.735256 qam24
19379000000-11.235256 qam25
20387000000-11.436256 qam26
21395000000-1235256 qam27
22403000000-11.735256 qam28
23411000000-11.735256 qam29
24419000000-11.536256 qam
30
Upstream looks okay
1257998964.65512016 qam4
2326000244.65512016 qam3
3394000464.8512016 qam2
4462000004.9512016 qam1
3ATDMA0000
4ATDMA0000
  • 2.25K
  • 141
  • 573
cje85
Problem sorter
Your downstream power levels are far too low and the current hot weather will be adding to the problem. If you wait for a day or two a member of the forum team will reply and arrange an engineer visit to sort it out.
mattcharlton
That would make sense - the cable runs around the side of an end terrace house, and the sun will have been on it all morning - things have improved slightly now.  Getting about 20-30mb.  So it's workable.
Thanks for getting back to me, I'll await a VM response 🙂
  • 646
  • 27
  • 49
Hello Mattcharlton, thank you for your post.
Having a look at the tests it looks like a power level issue so we would like to send an engineer out for you as soon as we can.
For this I'll pop you over a private message with some security questions so we can access the account, if you can please respond to this by clicking the purple envelope in the top right.
Thank you, Emily.
mattcharlton
Thanks Emily - I'll respond as soon as I get the message 🙂
