VM will not deal with any non VM equipment
But see this...
To address the wifi issues, VM now supply “wifi Pods” (no longer doing cheap and cheerless “boosters”). However, their Pods are only free to customers on the 1GB, Volt (or old Ultimate Oomph) packages - is that you? If so they are worth trying - they should work for you.
You do have to call in to order the first one (cant do it online the website is borked) - or try the web-chat or Whatsapp functions (that has worked for some) - or just wait here for a VM person to respond in a day or two and they will sort the first one for you .
If not… you will be charged £5/month (note - BT charge £10/mo for their whole home wifi solution). It’s a simple solution and should work for you. However, you would soon pay off that cost by buying your own wireless solution that will be yours to own and use forever, although the VM Pods should be a simpler option.
You would need to get either a… (1) Mesh System, (2) Wireless router, (3) Wireless access point (4) A combination of (2,3).
