  • 20
Message 1 of 9
Issue with broadband
Hello,
I am frequently getting disconnected from broadband. I called the technical team but no solution and they said that the back office team is going to monitor and update. It's almost a week now and no update.
Below messages in router log:
12/12/2019 07:03:30 Critical No Ranging Response received
12/12/2019 07:03:34 Warning! RCS Partial Service;CM-MAC
12/12/2019 07:13:9 critical SYNC Timing Synchronization failure - Loss of Sync
I am fed up with the broadband service since last few months which is not stable. Also getting only 15-20 Mbps speed but I am paying for the speed of 100 Mbps.
Regards,
-Sunil
  • 1.82K
  • 260
  • 409
Super solver
Message 2 of 9
Re: Issue with broadband
Hello
How are you doing the speedtest is it either wired or wireless, wired is always the best option. If wired can you please do the following :-
Can you please post your network stats from the hub
Open a Web browser (e.g. Internet Explorer) and enter the address http://192.168.0.1
Note: If you have enabled Modem Mode on your Hub 3.0 you will need to use 192.168.100.1 instead.
Posting the stats by copy and paste will remove all personal information so no breaches.
Do not login but click on where it says "Check Router Stats" and then copy and post from the following 4 tabs, Downstream, Upstream, Configuration and Network logs (if they are pasted then all personal information is * out) and we can check your power level, also while you about that can you please go around and check that all connectors to VM equipment are hand tight. Also while doing this please check for any damage to cable, or un-terminated connection without either coax or a terminator.
Also please run "Check service status" at the top right of this forum and call 0800 561 0061 to check for local issues.
Also one think you can do is too signup at https://www.thinkbroadband.com/broadband/monitoring/quality and setup a broadband quality monitor which will keep an eye on you connection by sending a small amout of data to the hub asking if it still on.
Regards Mike
I dont work for VirginMedia all opinions are my own.
39 years in IT.
  • 20
Message 3 of 9
Thanks, Mike for your quick response.
See below logs.
Cable Modem Status
Item        Status      Comments
Acquired Downstream Channel (Hz)        139000000   Locked
Ranged Upstream Channel (Hz)        39399952     Locked
Provisioning State        Online
Channel                 Frequency (Hz)            Power (dBmV)         SNR (dB)                       Modulation                  Channel ID
1                            139000000                   4.1            35             256 qam                       1
2                            147000000                   4               35             256 qam                       2
3                            155000000                   4.5            35             256 qam                       3
4                            163000000                   4.6            35             256 qam                       4
5                            171000000                   4.6            35             256 qam                       5
6                            179000000                   4.3            34             256 qam                       6
7                            187000000                   4.3            35             256 qam                       7
8                            195000000                   4.1            35             256 qam                       8
9                            203000000                   4.5            35             256 qam                       9
10                          211000000                   4.1            34             256 qam                       10
11                          219000000                   4.3            35             256 qam                       11
12                          227000000                   3.7            34             256 qam                       12
13                          235000000                   3.2            34             256 qam                       13
14                          243000000                   3.2            34             256 qam                       14
15                          251000000                   3.2            34             256 qam                       15
16                          259000000                   4               34             256 qam                       16
17                          267000000                   4.5            34             256 qam                       17
18                          275000000                   4.9            34             256 qam                       18
19                          283000000                   4.4            34             256 qam                       19
20                          291000000                   4.5            34             256 qam                       20
21                          299000000                   3.9            34             256 qam                       21
22                          307000000                   4               33             256 qam                       22
23                          315000000                   3.7            33             256 qam                       23
Channel                 Locked Status              RxMER (dB)                              Pre RS Errors               Post RS Errors
1                            Locked                         35.5          33295966                              324241
2                            Locked                         35.5          33057310                              700041
3                            Locked                         35.5          32668744                              3301919
4                            Locked                         35.2          30887584                              4904094
5                            Locked                         35.5          28706131                              1943332
6                            Locked                         34.9          26708237                              3861007
7                            Locked                         35.4          24624000                              2300595
8                            Locked                         35.7          23288645                              729066
9                            Locked                         35.5          21388079                              538494
10                          Locked                         34.9          20910981                              429104
11                          Locked                         35             19020918                              383261
12                          Locked                         34.9          19660681                              112967
13                          Locked                         34.4          20615795                              329035
14                          Locked                         34.4          21800699                              388321
15                          Locked                         34.4          21014119                              62432
16                          Locked                         34.4          19456401                              586872
17                          Locked                         34.3          16747778                              1175849
18                          Locked                         34.6          14464623                              1038376
19                          Locked                         34.9          12821972                              179714
20                          Locked                         34.4          12733932                              169410
21                          Locked                         34.3          12296578                              801271
22                          Locked                         33.9          12342076                              607121
23                          Locked                         33.9          12187165                              31185
24                          Locked                         33.8          11792257                              40800
Refresh data
Channel         Frequency (Hz)  Power (dBmV)   Symbol Rate (ksps)             Modulation        Channel ID
1                    39399952           5.025                  5120                 64 qam               4
2                    60299660           5.1                      5120                 64 qam               1
3                    53700005           5.1                      5120                 64 qam               2
4                    46199894           5.1                      5120                 64 qam               3
Channel         Channel Type     T1 Timeouts      T2 Timeouts    T3 Timeouts       T4 Timeouts
1                    ATDMA             0                         0                       0             0
2                    ATDMA             0                         0                       0             0
3                    ATDMA             0                         0                       0             0
4                    ATDMA             0                         0                       0             0
Time              Priority    Description
12/12/2019 08:06:30     critical          No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/12/2019 08:06:30     Warning!      RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/12/2019 08:08:24     critical          No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/12/2019 08:08:27     Warning!      RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/12/2019 08:10:19     critical          No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/12/2019 08:10:19     Warning!      RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/12/2019 08:10:20     critical          No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/12/2019 08:10:22     Warning!      RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/12/2019 08:12:14     critical          No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/12/2019 08:12:15     Warning!      RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/12/2019 08:14:18     critical          SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/12/2019 08:14:41     Warning!      RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/12/2019 08:16:3       critical          No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/12/2019 08:16:8       Warning!      RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/12/2019 08:17:58     critical          No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/12/2019 08:18:0       Warning!      RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/12/2019 08:19:52     critical          SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/12/2019 08:19:58     Warning!      RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/12/2019 08:22:58     critical          SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/12/2019 08:23:46     Warning!      RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
I have created an account on thinkbroadband and currently monitoring is in progress.
I also checked my cables and they are tight.
Regards,
-Sun
  • 3.66K
  • 170
  • 289
Message 4 of 9
.Hi sbuja,
Thanks for posting. I am sorry for the broadband issues. I've taken a look in the background and we do need a tech visit to fix this. I'll PM you to arrange.
Kind regards,
John_GS
  • 3.66K
  • 170
  • 289
Message 5 of 9
Great, please let us know how the visit goes.
Kind regards
John_GS
  • 20
Message 6 of 9
See below the broadband monitor history.
  • 3.66K
  • 170
  • 289
Message 7 of 9
My apologies for this but am glad we've booked an engineer visit. Please do let us know how the visit goes.
Kind regards,
John_GS
  • 20
Message 8 of 9
Thanks, John, The engineer visited and he did the checks and found that there is a fault at the cabinet. He called another engineer to visit and the engineer is going to visit this afternoon at the cabinet to resolve that issue. He was talking about some low signal at the cabinet. Let's wait and see what the other engineer find during his checks.
  • 3.66K
  • 170
  • 289
Message 9 of 9
Thanks for coming back to me, hopefully all is fixed soon.
Kind regards,
John_GS
