  • 18
nigbates
Message 1 of 8
Internet speed
for the last couple of days our  broad band speed has been a lot lower than normal.  We normally get 100-150, currently we see max 40.
I have tested with and without LAN cable, from many devices.  All report the same speeds.
I have also tried the online VM service checker which reports no problems.
Any service issues in our area please?
  • 8.97K
  • 922
  • 1.4K
Message 2 of 8
Re: Internet speed
What package you on and which Hub do you have?  Are you using powerline adapters at all ?
  • 18
nigbates
Message 3 of 8
Re: Internet speed
no adapters, super hub 2 on vivid 152
hub in modem mode.
TV is also struggling with channels last 2 days
  • 8.97K
  • 922
  • 1.4K
Message 4 of 8
Re: Internet speed
Post up your Hub/network connection details and someone will check to see if there is a problem there.  Go to http://192.168.0.1  (or http://192.168.100.1 ) in your browser [there is no need to login] and then click on the  “router status” icon at  top right - and then copy/paste 3 sets of data onto here - the downstream, upstream , &  network logs.  Don't worry about the formatting it can be easily read (by others & not by me!), but try and avoid using screen shots & don’t include personal data or mac addresses
  • 18
nigbates
Message 5 of 8
Re: Internet speed
First Time
Last Time
Priority
Error Number
Description
28/11/2018 13:09:13 GMT
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Warning (5)
84020200
Lost MDD Timeout
Downstream
DS-1
DS-2
DS-3
DS-4
DS-5
DS-6
DS-7
DS-8
Frequency (Hz)
178750000
138750000
146750000
154750000
162750000
170750000
186750000
194750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)
Locked
Locked
Locked
Locked
Locked
Locked
Locked
Locked
Channel ID
6
1
2
3
4
5
7
8
Modulation
256QAM
256QAM
256QAM
256QAM
256QAM
256QAM
256QAM
256QAM
Symbol Rate (Msym/sec)
6.952000
6.952000
6.952000
6.952000
6.952000
6.952000
6.952000
6.952000
Interleave Depth
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)
2.73
5.30
3.45
4.16
5.45
3.85
3.89
5.27
RxMER (dB)
34.21
28.57
26.09
28.94
32.07
30.76
34.63
32.41
Pre RS Errors
234743980
1970911284
55628130
-1603893961
695294611
-1990149863
1557599466
12096874
Post RS Errors
37125
45841189
18352338
1405518540
13859
36258
15778
17246
Upstream
US-1
US-2
US-3
US-4
Channel Type
2.0
2.0
2.0
2.0
Channel ID
4
3
2
1
Frequency (Hz)
53700000
27400000
35800000
45800000
Ranging Status
Success
Success
Success
Success
Modulation
16QAM
16QAM
16QAM
16QAM
Symbol Rate (Sym/sec)
5120000
5120000
5120000
5120000
Mini-Slot Size
2
2
2
2
Power Level (dBmV)
52.00
52.00
52.00
52.00
T1 Timeouts
0
0
0
0
T2 Timeouts
0
0
0
0
T3 Timeouts
0
0
0
0
T4 Timeouts
0
0
0
0
  • 8.97K
  • 922
  • 1.4K
Message 6 of 8
Re: Internet speed
I am no expert but your upstream power levels are out of range at 52 dBmv (50 is recommended top max).  Someone more qualified will comment but i think you may need a technician's visit to adjust the.
  • 11.8K
  • 1.08K
  • 2.56K
griffin
Message 7 of 8
Re: Internet speed
As JBrennand says your upstream power levels are maxxed out . (52dBmv 16QAM, 51dBmv 64QAM  or four channels)
Your downstream SNR is also too low.
I would give  the coax cable from the Hub to the cable entry point a quick once over, checking for obvious signs of damage and kinks and check all connectors are hand tight. before arranging a tech visit
  • 18
nigbates
Message 8 of 8
Re: Internet speed
God call, thanks.
Found a few that were ever so slightly loose. Back up to full speed again now.
