04-08-2022 11:50 - edited 04-08-2022 12:15
I live in area 7, and VM completed work in the area yesterday (3rd August). Today, speedtest.net is reporting anything from 100Mbps to 180Mbps.
I'm on M600, and generally before this was getting 580-620Mbps regularly. Yes, it is school holidays, but in the past it has only dropped to 300Mbps or so for brief periods, and this has been all day.
I have rebooted the router, used a direct LAN connection to 2 laptops, and also a connection via an Asus XT-8 in modem mode, and all report the same speeds.
Since the reboot there have been no timeouts, and the upstream log shows this:
1 39400000 49.8 5120 64 qam 4
2 46200000 49.8 5120 64 qam 3
3 53700000 50.5 5120 64 qam 2
4 60300000 51 5120 64 qam 1
Downstream shows this:
1 203000000 3.7 40 256 qam 9
2 139000000 4.3 38 256 qam 1
3 147000000 4.1 38 256 qam 2
4 155000000 4 38 256 qam 3
5 163000000 4 38 256 qam 4
6 171000000 4 38 256 qam 5
7 179000000 4 38 256 qam 6
8 187000000 4 38 256 qam 7
9 195000000 3.9 38 256 qam 8
10 211000000 3.7 40 256 qam 10
11 219000000 3.7 40 256 qam 11
12 227000000 3.7 38 256 qam 12
13 235000000 3.5 38 256 qam 13
14 243000000 3.2 38 256 qam 14
15 251000000 3.5 40 256 qam 15
16 259000000 3.5 40 256 qam 16
17 267000000 3.5 40 256 qam 17
18 275000000 3.5 40 256 qam 18
19 283000000 3.5 40 256 qam 19
20 291000000 3.5 40 256 qam 20
21 299000000 3.7 38 256 qam 21
22 307000000 3.5 40 256 qam 22
23 315000000 3.7 40 256 qam 23
24 323000000 3.9 40 256 qam 24
No post RS errors exist.
Any ideas? I've done remote tests using the website and all come back ok. Nothing internally has changed other than I had a couple of days not using my laptop
Edit> as a quick addition, upload speeds are consistent.. 40Mbps all the time.
on 04-08-2022 16:58
on 04-08-2022 17:23
Yeah, done the test in modem mode after a reset.
I used to run in modem mode but now run my iot network from the VM hib and my own network is behind that. The xt8 is on the DMZ port
all runs very well and before used to get full speed
04-08-2022 18:06 - edited 04-08-2022 18:07
Maybe a case of more people downloading and VM eyes on the money then on the network.
on 04-08-2022 18:48
on 05-08-2022 07:22
Seems overnight that things have corrected themselves.
I now get 650Mbps at the router, and 450Mbps from the PCs... I wonder what caused that, and the reset
