  • 12
rickster9000
Message 1 of 8
Internet Speed + Loss of internet entirely
Recently I have been experiencing up to a 50% drop in my internet speed (Vivid 100). Also I have been losing access to the internet frequently, these loses in internet sometimes only last for a few minutes but have lasted as long as 13 hours(This was on Christmas day). When accessing the router settings it says Access Denied next to the Internet icon while the internet is down and will persist even with a reboot of the router. I have a super hub 3 and I did speed tests on a desktop that is directly connected via Ethernet to the router.
  • 118
  • 17
MikeRobbo
Dialled in
Message 2 of 8
Re: Internet Speed + Loss of internet entirely
It might be an idea to do a speed check using a wifi device just to rule out a problem with the network card in the PC.
  • 12
rickster9000
Message 3 of 8
This is a speed test i just did on a different wired device
  • 6.75K
  • 707
  • 1.04K
Legend
Message 4 of 8
Check all your coax connections are in nice and "finger" tight at the Hub and wall box and at any splitters/attenuators/etc and that the internal wiring is ok with no kinking or chaffing (rabbit chews!).  Also check that all looks good with the outside cabling and wall box.
If that’s all good.... post up your Hub/network connection details and someone will check to see if there is a problem there.  In your browser’s URL box type in  http://192.168.0.1  (or http://192.168.100.1 - if in modem mode) and hit return.   On the first page up [there should be no need to login if you have done so before] click on the “router status” text at bottom middle of first page up and then copy/paste 3 sets of data onto here - the downstream, upstream, &  network logs.  Don't worry about the formatting it can be easily read, but try to avoid using screen shots & don’t include personal data or mac addresses - blank them out.
  • 12
rickster9000
Message 5 of 8
Thanks for the reply. I checked all the cables and they are all fine. Just to be sure I unplugged and plugged them all back in. I will post up and downstreams when my Internet comes back on as right after I sent that reply it went down.
  • 12
rickster9000
Message 6 of 8
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
323000000
-13.3
35
256 qam
24
2
315000000
-13.5
35
256 qam
23
3
307000000
-14
35
256 qam
22
4
299000000
-13.8
34
256 qam
21
5
291000000
-14.3
35
256 qam
20
6
283000000
-14.4
34
256 qam
19
7
275000000
-14.2
35
256 qam
18
8
267000000
-14.4
35
256 qam
17
9
259000000
-14.3
34
256 qam
16
10
251000000
-14.3
34
256 qam
15
11
243000000
-14.4
34
256 qam
14
12
235000000
-14
34
256 qam
13
13
227000000
-14.2
34
256 qam
12
14
219000000
-13.9
35
256 qam
11
15
211000000
-14.5
35
256 qam
10
16
203000000
-14.8
34
256 qam
9
17
195000000
-14.5
34
256 qam
8
18
187000000
-15.3
34
256 qam
7
19
179000000
-15.2
34
256 qam
6
20
171000000
-15.5
33
256 qam
5
21
163000000
-15.7
33
256 qam
4
22
155000000
-16
33
256 qam
3
23
147000000
-15.7
33
256 qam
2
24
139000000
-16.7
32
256 qam
1
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
35.5
34
0
2
Locked
35.5
41
0
3
Locked
34.9
177
0
4
Locked
35
224
0
5
Locked
34.9
224
0
6
Locked
35
315
0
7
Locked
34.9
194
0
8
Locked
34.9
408
0
9
Locked
35
302
0
10
Locked
35
200
0
11
Locked
34.9
363
0
12
Locked
35
277
0
13
Locked
34.9
442
0
14
Locked
35
73
0
15
Locked
34.6
464
0
16
Locked
34.4
597
0
17
Locked
34.9
320
0
18
Locked
33.9
3072
0
19
Locked
34.3
1414
0
20
Locked
33.9
5985
0
21
Locked
33.9
6483
0
22
Locked
33.4
19886
0
23
Locked
33.4
322834
27256
24
Locked
32.6
368877
243684
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
46200000
57
5120
64 qam
1
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
4
0
Time
Priority
Description
2019-01-12 15:42:04.00
critical
No Ranging Response received - T3 time-out;CM-MAC=MAC= CM-QOS=1.1;CM-VER=3.0;
2019-01-12 15:43:08.00
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC= CMTS CM-QOS=1.1;CM-VER=3.0;
2019-01-12 15:43:36.00
critical
No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2019-01-12 15:44:42.00
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2019-01-12 15:45:10.00
critical
2019-01-12 15:50:48.00
critical
2019-01-12 15:52:45.00
critical
2019-01-12 15:53:37.00
critical
2019-01-12 15:57:57.00
Warning!
Lost MDD Timeout;CM-MAC=CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
Warning!
MDD message timeout;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2019-01-12 15:58:11.00
critical
2019-01-12 16:00:17.00
critical
2019-01-12 16:02:33.00
critical
2019-01-12 16:03:23.00
critical
2019-01-12 16:03:57.00
critical
2019-01-12 16:05:04.00
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=c;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2019-01-12 16:05:35.00
critical
2019-01-12 16:19:52.00
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2019-01-12 16:49:41.00
critical
2019-01-12 16:51:32.00
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=c;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
  • 531
  • 43
  • 158
DreamOfCheese
Rising star
Message 7 of 8
Your downstream levels are really low, and your modem has only locked a single upstream channel and the power level on that is really high.
You'll need to either wait up to a week for a VM forum team member to respond to this topic or call the support line and request a technician visit to fix the levels.
  • 12
rickster9000
Message 8 of 8
Thanks for the quick response. I called up and they are going to send someone out on Monday to hopefully fix the problem.
