Message 1 of 5
Intermittent connection
Hi. I am a new customer on 350mb. The connection worked well for the first month but the connection is now dropping intermittently, especially in the evenings. I am getting 350mb throughput from my wifi router. Grateful if someone could take a look at my logs and let me know if there is anything unusual.
STATUS
Item
Status
Comments
194750000
Locked
Ranged Upstream Channel (Hz)
25800122
Locked
Provisioning State
Online
DOWNSTREAM
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
194750000
3.4
37
256 qam
8
2
202750000
3
37
256 qam
9
3
210750000
2.7
37
256 qam
10
4
218750000
2.5
37
256 qam
11
5
226750000
2.4
37
256 qam
12
6
234750000
2.5
38
256 qam
13
7
242750000
2.5
38
256 qam
14
8
250750000
2.7
38
256 qam
15
9
258750000
2.7
38
256 qam
16
10
266750000
2.7
38
256 qam
17
11
274750000
2.5
38
256 qam
18
12
282750000
2.9
38
256 qam
19
13
290750000
3
38
256 qam
20
14
298750000
3.2
38
256 qam
21
15
306750000
3
38
256 qam
22
16
314750000
2.7
38
256 qam
23
17
322750000
2.5
38
256 qam
24
18
402750000
2
38
256 qam
25
19
410750000
2.2
38
256 qam
26
20
418750000
2
38
256 qam
27
21
426750000
2.4
38
256 qam
28
22
434750000
2.2
38
256 qam
29
23
442750000
1.9
38
256 qam
30
24
450750000
2
38
256 qam
31
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
37.6
110335
525063
2
Locked
37.6
107039
518582
3
Locked
37.6
105250
506968
4
Locked
37.3
97968
438752
5
Locked
37.6
96798
434035
6
Locked
38.6
96970
481006
7
Locked
38.6
94711
465870
8
Locked
38.6
96704
486726
9
Locked
38.6
96120
470061
10
Locked
38.6
95680
461586
11
Locked
38.6
95470
463145
12
Locked
38.6
94487
464939
13
Locked
38.6
95347
457349
14
Locked
38.9
95776
450080
15
Locked
38.9
98855
432366
16
Locked
38.6
102742
411236
17
Locked
38.6
108959
386156
18
Locked
38.9
153463
257784
19
Locked
38.9
158988
233290
20
Locked
38.9
162007
219391
21
Locked
38.9
164348
200516
22
Locked
38.9
165917
196835
23
Locked
38.9
165611
202070
24
Locked
38.9
167097
201771
UPSTREAM
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
25800122
3.975
5120
64 qam
18
2
32600000
4.025
5120
64 qam
17
3
39400000
4.125
5120
64 qam
16
4
46200137
4.2
5120
64 qam
15
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
NETWORK LOG
Time
Priority
Description
22/06/2020 23:10:33
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 23:10:33
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 23:10:33
Warning!
22/06/2020 23:10:31
critical
22/06/2020 23:10:31
Warning!
22/06/2020 23:10:30
critical
22/06/2020 23:09:47
Warning!
22/06/2020 23:09:46
critical
22/06/2020 23:09:46
Warning!
22/06/2020 23:09:45
critical
22/06/2020 23:08:41
Warning!
22/06/2020 23:08:40
critical
22/06/2020 23:08:39
Warning!
22/06/2020 23:08:39
critical
22/06/2020 23:08:33
Warning!
22/06/2020 23:08:33
critical
22/06/2020 23:04:21
Warning!
22/06/2020 23:04:21
critical
22/06/2020 23:04:20
Warning!
22/06/2020 23:03:52
critical
  • 20.96K
  • 1.14K
  • 2.7K
Message 2 of 5
Re: Intermittent connection
What speeds do you get when wired?
Message 3 of 5
Thank you for replying to my post. I didn't check my wired connection as I was getting such high throughput from the wifi router (a TPLINK - my VM router is in modem mode) but will do so if the issue returns. However, I think the issue is upstream based on the below graph. Will see if it returns again tonight.
Message 4 of 5
Here is a link to my graph as the image doesn't seem to have uploaded.
  • 3.02K
  • 168
  • 278
Message 5 of 5
Hey there rsh83,
Welcome to our Community Forum and sorry to hear about your intermittent broadband connection. I've had a look at your network details and I can't see any issues or errors. However you are in modem mode so there's only so much I can see. I'm unsure whether you're still having problems since you last posted but if you are, please put the Hub back into router mode so we can take another look.
Lisa
