arkumar
Intermittent connection with very low speed and intermittent connection
I regret that I joined the virgin media.
I am fed up with speed very slow and the maximum speed occasionally I can get is 38 M but most of the time is under 20 M. It comes for few minutes and disconnect itself.. I bought 500 M package. I have tried so many time re-booting the box and re-set the WiFi box, I followed all the instructions on the phone voice recorded answers and also in wave site. I phoned and I waited nearly 30 minutes so many times but they never answered.
Shall I need to change service provider?
Because virgin media internet is fake. it says 500 M but I get only under 20 M occasionally even though I use one equipment.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Intermittent connection with very low speed and intermittent connection
How are you connecting Wi-Fi or ethernet cable ?
It can be difficult diagnosing problems without some basic information.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Can you set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the other side of the Hub, it will take a few hours to get any kind of trend showing although you can post the link straight away.
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
