on 14-02-2022 12:06
I have Gig1 broadband and phone and get a patchy connection in the morning with 60s ish disconnections, T3s, and also varying speed. I accept it might be something to with my hardware however please can someone check that my signal levels etc are up to scratch just as a process of elimination? Thanks! 🙂
Shub4, Hardware V11
Downstream
Channel, Frequency (Hz), Power(dBmV), SNR(dB), Modulation, Channel ID
25 331000000 6.199997 40.366287 QAM256 25
1 139000000 4.400002 40.366287 QAM256 1
2 147000000 4.699997 38.983261 QAM256 2
3 155000000 5.000000 40.366287 QAM256 3
4 163000000 5.099998 38.983261 QAM256 4
5 171000000 4.900002 40.366287 QAM256 5
6 179000000 4.900002 40.366287 QAM256 6
7 187000000 4.699997 40.366287 QAM256 7
8 195000000 4.599998 40.366287 QAM256 8
9 203000000 4.800003 38.983261 QAM256 9
10 211000000 5.400002 40.366287 QAM256 10
11 219000000 5.400002 40.366287 QAM256 11
12 227000000 5.699997 40.946209 QAM256 12
13 235000000 5.800003 40.366287 QAM256 13
14 243000000 6.000000 40.366287 QAM256 14
15 251000000 5.599998 40.366287 QAM256 15
16 259000000 6.199997 40.366287 QAM256 16
17 267000000 6.099998 40.366287 QAM256 17
18 275000000 6.199997 40.366287 QAM256 18
19 283000000 6.000000 40.946209 QAM256 19
20 291000000 6.199997 40.366287 QAM256 20
21 299000000 6.199997 40.366287 QAM256 21
22 307000000 6.699997 40.946209 QAM256 22
23 315000000 6.500000 40.946209 QAM256 23
24 323000000 6.500000 40.366287 QAM256 24
26 339000000 6.599998 40.366287 QAM256 26
27 347000000 6.400002 40.366287 QAM256 27
28 355000000 6.599998 40.366287 QAM256 28
29 363000000 6.699997 40.366287 QAM256 29
30 371000000 6.900002 40.366287 QAM256 30
31 379000000 6.900002 40.946209 QAM256 31
32 387000000 7.199997 40.946209 QAM256 32
Upstream
Channel, Frequency(Hz), Power(dBmV), Symbol Rate(ksps), Modulation, Channel ID
1 46200000 44.520599 5120 KSym/sec 64QAM 1
2 39400000 44.770599 5120 KSym/sec 64QAM 2
3 25800000 44.520599 5120 KSym/sec 64QAM 4
4 32600000 44.270599 5120 KSym/sec 64QAM 3
on 14-02-2022 16:26
on 17-02-2022 12:30
Hi mildenhall,
Thanks for your post and welcome to the forums. It's great having you on board with us in the Community.
I'm sorry to hear that you are having an issue with your network. Checking our systems, I can see all is looking well with the Hub in terms of power and signal levels, uptime and time outs. There are no faults open that may be affecting you either.
Can you expand on what sort of set up you have there?
It may help to set up a broadband quality monitor here. Once you've done this, please post your live URL link so we can monitor things and we can go from there.
Keep us posted 🙂
22-02-2022 13:38 - edited 22-02-2022 13:42
Thank you both for your replies.
I am using a Hub4 in modem mode with a brand new Netgear Nighthawk AX11000. I have taken speed tests using a Cat6 cable via a 1gigabit managed switch box from my i7 Windows 11 ASUS laptop and i7 Dell Windows 10 laptop. I'll keep monitoring the situation.
My main concern is intermittent disconnects when I am live streaming seminars on Thursdays and Fridays. The speed is just acceptable at 600mbps however I am paying for 1gbps.
on 22-02-2022 16:10
Any QoS set on your Router? What does www.samknows.com/realspeed show with a wired test direct to the Hub ? Can you test with Windows in "Safe Mode with Networking support"
Your BQM looks pretty perfect btw.
