Borag
  • 9
Message 1 of 17
Intermittent Connection I have been having for over 6 months M100
HI I have been having troubles with my connection for a while now, have phoned customer service a number of times with different results. I originally got a new router as the one I had was a couple of years old, then had a technician around who tidied up the wires between outside my house to my router. This was may be back in May. Since then I still have the same problem. However, since about two weeks ago I have been using BQM which shows how intermittent my connection is.
I have been struggling to get help from calling customer service and have now decided to post here as a last ditch effort to see if I can get any answers.
Here is how the connection is today.
This is worse than usual but average is like this.
I have been told a number of times to reset my router, check all connections etc. But as this shows this is something that is out of my hands. If it's helpful I use a desktop connected via ethernet.
Looking forward to any assistance.
Thanks.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 17
Re: Intermittent Connection I have been having for over 6 months M100
Your BQM is showing typical signs of over utilisation.
Can you post your Hub data to see if we can find something that they will have to action.
Can you please
Borag
  • 9
Message 3 of 17
14270000003.240256 qam37
22670000003.240256 qam17
3275000000340256 qam18
4283000000340256 qam19
52910000003.240256 qam20
62990000003.240256 qam21
73070000003.240256 qam22
83150000003.540256 qam23
9323000000440256 qam24
103310000004.140256 qam25
113390000004.340256 qam26
12347000000440256 qam27
133550000004.140256 qam28
14363000000440256 qam29
153710000003.540256 qam30
163790000003.238256 qam31
173870000003.240256 qam32
183950000003.240256 qam33
194030000003.240256 qam34
20411000000340256 qam35
21419000000340256 qam36
224350000002.940256 qam38
234430000002.940256 qam39
24451000000338256 qam40
Borag
  • 9
Message 4 of 17
1Locked40.3370
2Locked40.3260
3Locked40.3250
4Locked40.3160
5Locked40.3140
6Locked40.3270
7Locked40.9330
8Locked40.9130
9Locked40.9260
10Locked40.3360
11Locked40.9240
12Locked40.3240
13Locked40.3230
14Locked40.9280
15Locked40.3160
16Locked38.9300
17Locked40.3340
18Locked40.9350
19Locked40.3560
20Locked40.3370
21Locked40.3380
22Locked40.9510
23Locked40.3110
24Locked38.9250
Borag
  • 9
Message 5 of 17
15370000043.3512064 qam2
23940000041.3512064 qam4
34620000042.8512064 qam3
46030000043.3512064 qam1
1ATDMA0020
2ATDMA0030
3ATDMA0020
4ATDMA0010
Borag
  • 9
Message 6 of 17
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
69834ncxv9873254k;fg87dsf
SFID740
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID739
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
Borag
  • 9
Message 7 of 17
Network LogTime Priority Description
16/11/2020 05:27:29noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/11/2020 05:27:29ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 21:28:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 04:25:2noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 04:25:2ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 12:56:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 17:29:57noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 17:29:57ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 13:05:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 08:30:20Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 02:05:57criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 02:05:57criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 01:48:17criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 01:45:0criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 01:44:28criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 01:41:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 01:33:2criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 01:31:37noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 01:29:15criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 01:29:10criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Anonymous
Not applicable
Message 8 of 17
The HUB stats look 'OK' (A blip on the 06/11), so unfortunately it may be a case of oversubscription in your area.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 17
Nothing in the Hub data jumps out as any kind of problem.
Can you post a 'Live Link' to your BQM please.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Borag
  • 9
Message 10 of 17
Sure, here it is.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/7770a014bf4414eb48dd110f0aa33e81e936917d
