Installed 1g hub5 2day upload is shocking
smithy01793
Had my hub5 installed 1gig service.
Then download seems prity spot on
How ever the upload is shocking
Only getting around 30-40 Meg
Also my ping is unacceptably high. 35-45
I have just left a 900meg service.
My ping on the 900meg service 95% of the time was around 9-15
And the upload was around 95-110 meg
Can anyone assist in anyway?
1 ACCEPTED SOLUTION
Accepted Solutions
Robert_P
Hello smithy01793
Sorry to hear of the connection issues experienced, we appreciate you taking the time to raise this via the forums.
From checking the connection and equipment, everything regarding your downstream channels looks fine but as mentioned there are issues with the upstream channels which would explain the issues experienced. here has been some errors reported since the last reboot which looks to have been a day or so ago. Firstly, can you reboot the hub for us so we can see if the errors return?
Regardless, this may need a technician visit, I will send you a Private Message to get some more details from you so keep an eye out for the envelope in the top right when signed into the forums.
Rob
10 REPLIES 10
Beth_G
Hi smithy0793,
Thanks for your post. I'm sorry to hear you've been experiencing some issues with your upload speeds.
Looking from here, I can see that your upstream power levels are outside of the normal parameters, which will be why your speeds aren't as high as expected.
I'll drop you a message here now so I can arrange an engineer visit to put the levels right.
Beth
Legend
"I have just left a 900meg service" ...  With another ISP ? What on earth were you thinking ?
carl_pearce
Community elder
Regardless of faults on the line you'll never see 9-15ms latency on VM HFC. Hopefully you have a HUB 5x and are on FTTP, else you are going to be disappointed with 20-25ms latency.
Robert_P
Hello smithy01793
Rob
hi i have rebooted for you attahced is the images you might need NW status page.pngNW Upload page 07-10-23.pngNW Status log 07-10-23.png
Yea i have FTTP Bud hence why I was a little disappointed
I am using a 2.5gig port and Cat7 and only one on this service ATM.,
I am going to try good old school port forwarding to see if this helps
smithy01793
Also the Software version on this hub seems a little old that is of course the naming convention is using the date
Software version
LG-RDK_4.6.24-2206.7
As we're discussing this via PM, please keep all relevant information there to help avoid confusion 🙂
Rob
Hi robert and Beth I have sent u guys another pm to hopefully get this resolved as u know the last engineer you guys kindly booked for me left as he could not resolve the issue. Apparently he escalated but it's been a good week or 2 since then with no contact.
Please please can we get this sorted as it has not worked correctly since it was installed
Thanks Tom
