blueyonder-user
Message 1 of 8
Inconsistent speeds and connection dropping out
Hi All,
Not sure what is up with my broadband at the mo, never had many problems with it and in the last month or so have been having various issues. The latest seems to have started about 2 nights ago when the connection was a bit choppy and dropping out. We now seem to have broadband sometimes at 100Mbs and then 5 mins later 20Mbps.
Rany VirginMedia and the guy was pretty unhelpful I got told to restart my laptop, change the ethernet cable I was using, clear cookies etc..... and while my speed has now been 100Mbps for the last 20 mins I'm not convinced it is going to stay this way. So as people here are a helpful bunch I thought I'd post my router status info here and see if anyone can spot any problems with it.
The Pre and Post RS errors on channels 7,8,9 seems to suggest there is a problem as they are called Errors and 8 in particular is quite high. Any and all help/info is greatly appreciated.
ChannelFrequency (Hz)Power (dBmV)SNR (dB)ModulationChannel Id
1299000000-1.935256 qam21
21710000000.435256 qam5
3179000000-1.536256 qam6
41870000000.536256 qam7
5195000000-335256 qam8
6203000000-1.235256 qam9
7211000000-1.533256 qam10
8219000000-4.528256 qam11
9227000000-1.231256 qam12
10235000000-435256 qam13
11243000000-1.534256 qam14
12251000000-0.735256 qam15
13259000000-336256 qam16
142670000000.236256 qam17
15275000000-2.736256 qam18
16283000000-0.235256 qam19
17291000000-135256 qam20
183070000000.536256 qam22
19315000000-1.936256 qam23
20323000000136256 qam24
21379000000-135256 qam25
22387000000-135256 qam26
23395000000-2.235256 qam27
24403000000036256 qam28
ChannelLockedRxMER (dB)Pre RS ErrorsPost RS Errors
1Locked35.700
2Locked35.7110
3Locked36.690
4Locked36.610
5Locked36.320
6Locked35.740
7Locked33.96650
8Locked28.6431110111197
9Locked312509650
10Locked35.510
11Locked34.9250
12Locked35.710
13Locked36.600
14Locked37.320
15Locked36.320
16Locked35.720
17Locked35.710
18Locked36.600
19Locked36.300
20Locked36.300
21Locked35.700
22Locked36.300
23Locked36.390
24Locked36.600
  • 9.06K
  • 933
  • 1.41K
Message 2 of 8
Re: Inconsistent speeds and connection dropping out
A few channels are out of range. Post up the same data for the Upstream ones and also the network logs.
blueyonder-user
Message 3 of 8
Hi, here are the updated data including the logs too, thanks
1299000000-1.735256 qam21
21710000000.235256 qam5
5195000000-2.735256 qam8
7211000000-1.534256 qam10
8219000000-4.430256 qam11
10235000000-3.935256 qam13
13259000000-2.936256 qam16
17291000000-0.935256 qam20
22387000000-0.935256 qam26
1Locked35.73798
2Locked35.74951106
3Locked36.6522291
4Locked36.6228962
5Locked35.7666693
6Locked35.7333841
7Locked34.31982352
8Locked30.1135059537263650
9Locked31.91055643923
10Locked35.7373831
11Locked34.4197121
12Locked35.7116320
13Locked36.3153818
14Locked36.674319
15Locked36.396428
16Locked35.53870
17Locked35.770816
18Locked36.62790
19Locked36.335334
20Locked36.31246
21Locked35.724811
22Locked35.77135135
23Locked35.736035
24Locked36.615628
ChannelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID
1603000095.1512064 qam1
2394000005.1512064 qam4
3461999745.1512064 qam3
4536999544.9512064 qam2
ChannelChannel TypeT1 TimeoutsT2 TimeoutsT3 TimeoutsT4 Timeouts
3ATDMA0000
4ATDMA0000
TimePriorityDescription
15/06/2019 16:13:32Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2019 16:13:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2019 16:14:44Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2019 16:15:36Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2019 16:16:4Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2019 16:17:25Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2019 16:17:27Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2019 16:17:32Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2019 16:18:40Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2019 16:21:5Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2019 16:23:32Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2019 16:27:39Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2019 16:28:40Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2019 16:38:44Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2019 16:39:50Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2019 16:41:50Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2019 18:00:4Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2019 18:24:29Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2019 18:49:26Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/06/2019 18:59:37Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 579
  • 92
  • 291
Message 4 of 8
You have noise/interference on your line, the S/N ratio is too low on a number of the downstream channels hence the high error rates on them, the upstream power levels are right on the upper bounds on three of the channels and nearing it on the 4th.
You need to either call back up and insist on an engineer visit or hold tight until one of the forum team spot this thread and offer to contact you directly - might take a few days or so though.
It's more likely that the fault is due to a bad connection or cracked coax cable outside or in the street cabinet but it can't harm to check if all the connections you can get to inside are nice and finger tight.
  • 979
  • 46
  • 87
Forum Team (Retired) Tom_S
Message 5 of 8
Hi blueyonder-user, welcome to our community forums.
I am sorry to hear that you've been experiencing issues with your services and we'd like to take a closer look for you.
I am going to send you a PM so we can discuss this further.
Tom_S
blueyonder-user
Message 6 of 8
Just to update the thread, I have since called Virgin Media another 2 times (Tuesday and Today) and the first guy made some sort of changes that meant I was getting 100Mbps again fairly consistently, but today I'm back down to 8Mbps and the guy today wants me to swap my CAT 5E ethernet cable for a CAT 6 one. I told him this was not going to make a difference as I have been using the same Laptop and Cable to test over the week and that was giving speeds of over 100Mbps so the cable is fine (at least he is sending me a CAT 6 cable.... I suppose)
Is there anything I can say to the guys on the phone to actually spark them in to action?
I told them I don't want to pay for my internet connection until the problem is fixed, but was told that as there is a connection I can't complain to anyone.
Hopefully @Tom_S will be able to help me out, I was just wary of giving my account details out to people on the internet, but  I just need this issue fixed now.
  • 9.06K
  • 933
  • 1.41K
Message 7 of 8
Did you reply to the personal message from Tom_S ? He is a bona fide VM support person who offered to help you.
Roland69uk
Message 8 of 8
My connection has been rubbish since i joined up 2/3 months ago,  never had this with BT.
Refresh data
1 210750000 0.2 38 256 qam 10
2 138750000 0.5 38 256 qam 1
3 146750000 0.5 38 256 qam 2
4 154750000 0.2 38 256 qam 3
5 162750000 0.2 38 256 qam 4
6 170750000 0.2 38 256 qam 5
7 178750000 0.4 38 256 qam 6
8 186750000 0.5 38 256 qam 7
9 194750000 0.5 38 256 qam 8
10 202750000 0.4 38 256 qam 9
11 218750000 0.2 38 256 qam 11
12 226750000 0.5 38 256 qam 12
13 234750000 0.2 38 256 qam 13
14 242750000 -0.2 38 256 qam 14
15 250750000 0 38 256 qam 15
16 258750000 0 38 256 qam 16
17 266750000 0.2 38 256 qam 17
18 274750000 0 38 256 qam 18
19 282750000 -0.5 38 256 qam 19
20 290750000 -0.5 38 256 qam 20
21 298750000 -0.5 38 256 qam 21
22 306750000 -0.4 38 256 qam 22
23 314750000 0 40 256 qam 23
24 322750000 0 38 256 qam 24
1 Locked 38.9 8 0
2 Locked 38.9 8 0
3 Locked 38.6 12 0
4 Locked 38.6 10 0
5 Locked 38.6 9 0
6 Locked 38.9 23 0
7 Locked 38.6 22 0
8 Locked 38.6 18 0
9 Locked 38.9 24 0
10 Locked 38.9 8 0
11 Locked 38.9 5 0
12 Locked 38.9 6 0
13 Locked 38.6 7 0
14 Locked 38.9 12 0
15 Locked 38.9 9 0
16 Locked 38.9 8 0
17 Locked 38.9 8 0
18 Locked 38.9 10 0
19 Locked 38.9 9 0
20 Locked 38.9 10 0
21 Locked 38.9 17 0
22 Locked 38.9 7 0
23 Locked 40.3 10 0
24 Locked 38.6 11 0
1 53700009 4.575 5120 64 qam 10
2 39400051 4.575 5120 64 qam 12
3 46199961 4.575 5120 64 qam 11
4 60300080 4.575 5120 64 qam 9
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
Refresh data
13/06/2019 19:43:52 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsl10016u+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/06/2019 06:24:7 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/06/2019 19:55:5 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/06/2019 20:08:55 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/06/2019 05:45:42 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/06/2019 09:25:19 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/06/2019 10:41:1 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/06/2019 10:48:51 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/06/2019 13:08:40 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/06/2019 15:36:23 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/06/2019 15:36:23 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsl10016u+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/06/2019 15:39:44 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2019 05:41:32 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2019 10:38:8 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2019 17:17:53 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2019 17:17:55 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2019 17:17:55 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2019 17:18:0 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2019 19:12:30 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
