on 02-02-2022 13:34
I had resurrected my last thread but i think its been lost.
Anyway. Im back again, same problem.
Ever since November when i switched to a HUB5, i have been getting dropouts.
I have a couple of threads on this problem. An engineer was sent out at the end of November stuck and attenuator on the back of my router did some checks and left.
It was ok for a few weeks and then it started to drop out.
I think i need to go back to my old router , how would i go about this as i no longer have it?
Ill post all my usual logs and BQM link
1 | 155000000 | 6.7 | 40 | QAM 256 | 3 |
2 | 139000000 | 6.9 | 40 | QAM 256 | 1 |
3 | 147000000 | 6.7 | 40 | QAM 256 | 2 |
4 | 163000000 | 6.8 | 40 | QAM 256 | 4 |
5 | 171000000 | 6.7 | 40 | QAM 256 | 5 |
6 | 179000000 | 6.6 | 41 | QAM 256 | 6 |
7 | 187000000 | 6.8 | 41 | QAM 256 | 7 |
8 | 195000000 | 7 | 41 | QAM 256 | 8 |
9 | 203000000 | 6.9 | 41 | QAM 256 | 9 |
10 | 211000000 | 7.3 | 41 | QAM 256 | 10 |
11 | 219000000 | 7.4 | 41 | QAM 256 | 11 |
12 | 227000000 | 7.5 | 41 | QAM 256 | 12 |
13 | 235000000 | 7.4 | 41 | QAM 256 | 13 |
14 | 243000000 | 7.3 | 41 | QAM 256 | 14 |
15 | 251000000 | 7.4 | 41 | QAM 256 | 15 |
16 | 259000000 | 7.4 | 41 | QAM 256 | 16 |
17 | 267000000 | 7.2 | 41 | QAM 256 | 17 |
18 | 275000000 | 7.3 | 41 | QAM 256 | 18 |
19 | 283000000 | 7.5 | 41 | QAM 256 | 19 |
20 | 291000000 | 7.5 | 41 | QAM 256 | 20 |
21 | 299000000 | 7.2 | 41 | QAM 256 | 21 |
22 | 307000000 | 7.3 | 41 | QAM 256 | 22 |
23 | 315000000 | 7.4 | 41 | QAM 256 | 23 |
24 | 323000000 | 7.2 | 41 | QAM 256 | 24 |
25 | 331000000 | 7 | 41 | QAM 256 | 25 |
26 | 339000000 | 7.1 | 40 | QAM 256 | 26 |
27 | 347000000 | 7.1 | 41 | QAM 256 | 27 |
28 | 355000000 | 6.9 | 41 | QAM 256 | 28 |
29 | 363000000 | 6.7 | 41 | QAM 256 | 29 |
30 | 371000000 | 6.8 | 41 | QAM 256 | 30 |
31 | 379000000 | 7 | 41 | QAM 256 | 31 |
1 | Locked | 40 | 317649 | 329445 |
2 | Locked | 40 | 122365 | 971888 |
3 | Locked | 40 | 99570 | 69281 |
4 | Locked | 40 | 212590 | 607460 |
5 | Locked | 40 | 226196 | 244723 |
6 | Locked | 41 | 74 | 413435 |
7 | Locked | 41 | 0 | 95 |
8 | Locked | 41 | 0 | 0 |
9 | Locked | 41 | 0 | 0 |
10 | Locked | 41 | 0 | 0 |
11 | Locked | 41 | 0 | 0 |
12 | Locked | 41 | 0 | 0 |
13 | Locked | 41 | 0 | 3 |
14 | Locked | 41 | 0 | 6 |
15 | Locked | 41 | 0 | 4 |
16 | Locked | 41 | 0 | 2 |
17 | Locked | 41 | 0 | 0 |
18 | Locked | 41 | 0 | 1 |
19 | Locked | 41 | 0 | 0 |
20 | Locked | 41 | 0 | 0 |
21 | Locked | 41 | 0 | 0 |
22 | Locked | 41 | 0 | 0 |
23 | Locked | 41 | 0 | 0 |
24 | Locked | 41 | 0 | 0 |
25 | Locked | 41 | 0 | 0 |
26 | Locked | 40 | 0 | 0 |
27 | Locked | 41 | 0 | 0 |
28 | Locked | 41 | 0 | 0 |
29 | Locked | 41 | 0 | 0 |
30 | Locked | 41 | 0 | 0 |
31 | Locked | 41 | 0 | 0 |
Channel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID1 | 60300000 | 44.3 | 5120 | QPSK | 1 |
2 | 53700000 | 43.8 | 5120 | QPSK | 2 |
3 | 46200000 | 43.5 | 5120 | QPSK | 3 |
4 | 39400000 | 43.5 | 5120 | QPSK | 4 |
Channel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
Time Priority Description02-02-2022 05:12:37 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
02-02-2022 01:56:05 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
01-02-2022 23:33:37 | notice | CM-STATUS message sent. Event Type Code: 5; Chan ID: 37; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
01-02-2022 23:33:25 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
01-02-2022 23:33:19 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
01-02-2022 23:33:16 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
01-02-2022 23:33:14 | notice | Honoring MDD; IP provisioning mode = IPv4 |
01-02-2022 23:33:05 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
01-02-2022 23:33:04 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
01-02-2022 23:33:00 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
01-02-2022 23:30:57 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
01-02-2022 23:30:53 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
01-02-2022 23:26:53 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
01-02-2022 23:26:53 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
01-02-2022 23:26:18 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
01-02-2022 22:03:52 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
BGM
on 02-02-2022 15:30
Your BB circuit needs attention. There are many SYNC errors, PostRS errors and your US channels should all be 64QAM. Bit of a mess really.
Phone it in or wait here a day or two for a VM Mod to pick this up.
on 04-02-2022 19:42
Sorry to hear the issue is still ongoing. I can see on our systems that there are issues that would need a technician to attend.
I will continue this in private messages so we ca discuss. Please look out for my PM in your inbox.
on 09-02-2022 13:26
Thank you for joining me on private message @BaronVonStrudel
Hopefully this will all be resolved for you now. Let us know if you have any other issues. We'll be here to help.
All the best,
