on 10-03-2022 04:44
So I check my download speed every few days to make sure I get what I am paying for, Samknows real speed would usually come back with around 1140 and 940 - Ookla would come back with around 940Mbps too. During all this the upload is a constand 52Mbps.
Noticed things going slow on Sunday and the speeds had dropped to around 94Mbps download.
I have two different 1Gb network cards in the PC and swiitching between those (and SH4 ports) made no difference.
After a couple of power resets of the PC and Hub4 all went back to the expected rates. I suispected the PC had got intob a weird state.
During yesterday I could tell from download speeds that things were not right again - and they were back to 94Mbs download and 52Mbps upload.
Tried the power resets again and still 94Mbps download via Ethenet. 5GHz Wifi is still working at over 300-400Mpbs which has never changed.
I have another device with a 1Gb card which would give similar speed results to those excepted - but that is now maxing at 94Mbps download too. A few other devices would usually achieve over 130Mpbs - and are all maxing at 94Mpbs too.
One device I could always get around 300Mbs download via Ethernet is now showing 94Mbps too - but still 300Mbs when switched to Wifi.
It seems the SH4 is auto-negotiating at 100 and not 1000 on all four ports. Config still shows 1 DOCSIS 3.1 channel connect and config download is still 1230000450.
Have done a pinhole factory reset and before doing any SH4 customisation I tried again and still only 94Mpbs on all four ports.
I am sure it is not a signal issue as Wifi is good and I'm getting between -1.1 and +3.0 on all power levels and between 37.3 and 38.8 on all SNR.
I've not seen anything in the logs to show a firmware update but the logs were lost here in the factory reset - currently cmreg-vmdg640-bbt076+voc-b.cm
I will call TS today and get them to suggest things but I can put the issue down to the SH4.
Power levels are mainly the same after the factory reset so within expected range.
Anyone any other ideas of things to try?
MOD EDIT: see message 109 for an update
Answered! Go to Answer
on 15-02-2023 12:42
That explains it. The update took its time to arrive but all seems good. Oh yes it is in modem mode.
Many thanks
Vassilis
on 15-02-2023 14:15
se1lad,
If you dim it down so it's not intrusive at night, then you cannot see hub behaviour in the daytime 😞
on 15-02-2023 14:58
@johndm wrote:se1lad,
I can't see any of my networking kit LED's as it's all in a "comms room". I can however, monitor all the traffic via the router's console.
on 20-02-2023 23:00
i recently had upgraded to gig 1 and my speed were never above 94 on ethernet
I had an engineer out and changed the router but no joy still slow internet so i googled slow ethernet on windows 11 and found this article
https://www.drivereasy.com/knowledge/easy-fix-windows-10-slow-internet/
fix 5 is what you want to sort it but do the opposite, the fix says disable it, you want to enable it
key in command prompt netsh interface tcp show global into the window and press Enter. Then check if Receive Window Auto-Tuning Level is set to normal. mine was set to disabled, if yours is set to disabled then key in the following:
To make it a bit more clear, type netsh int tcp set global autotuninglevel=normal into an administrative command prompt to fix issue.
my speed is now 1.1 ggig according to fast.com and samknows, i have spent over a week trying to sort this out, my whole house is wired for ethernet and i have checked every wall jack and every cable and only found 1 fault but that wasnt the problem, this is a new pc and i got it a week before i upgraded to gig 1, am chuffed to bits now, will have to hava beer or 2 to celebrate !!
on 22-02-2023 12:18
My firmware on the hub 4 has been updated and i'm still getting the 94mbps cap regularly.
Still trying to get a hub 5 but to no avail.
on 22-02-2023 13:13
Didu try the above fix, mine is working great now and all it was was a setting on the pc
on 25-02-2023 02:24
Well i looked at the fix but it wont fix the issue as it happens across multiple wired device and some are not even running windows.
on 25-02-2023 18:52
Are you using a network switch? One of mine was only fast ethernet capable of 100mbps so I changed that too
on 28-04-2023 00:03
Thank you, worked great! 👍
