on 12-02-2022 12:33
Im have M500 and get the correct speed in router mode but when I change to modem mode I only get 220M,
I use a tp link archer ax50 for my router
please can someone help
Answered! Go to Answer
on 12-02-2022 13:10
I just disabled it and unchecked any priorities and set speed manually, problem solved immediately
thx Rod
12-02-2022 12:49 - edited 12-02-2022 12:50
Do you have QoS/BWM enabled on your router? some routers can't handle the speed with it on.
on 12-02-2022 13:10
thx Rod
