on 24-10-2021 16:22
Hello ladies and gents,
I very recently upgraded to the wonderful 1gig service (just over a week ago) and was surprised to learn that the modem on had 1gig ports I have a lovely 10gigabit setup through out my home including WiFi 6 AP and would like to get the most from them.
I understand there is now a new hub 5 out and how go about getting a swap to this hub I spoke to a fairly surly member of the retentions team to get info and was fobbed of being told he doesn’t really know anything about it and he is sure it’s invite only could I just confirm this?
Alternatively is there a team I can reach out to and maybe be placed on a waiting list etc I want to get the most out of my connection.
Cheers
Answered! Go to Answer
24-10-2021 16:38 - edited 24-10-2021 17:06
I too, have a 10Gb backbone at home, I was able to achieve full VM speed to the home network using a balanced LAGG with 2x 1Gb cables connected to the Hub 4. Seeing 1.1Gb on the LAN
Until VM announce 2Gb is it even worth installing a hub5 when you want to connect in modem mode etc.
on 24-10-2021 16:38
The Hub5 is not generally available and is currently only available to invited customers.
on 24-10-2021 20:53
How do you get two lan ports to work for full speed on hub 4? I have an asus wifi 6 router that is capable or wan aggregation so how do i get the hub 4 to support it?
on 25-10-2021 13:26
I will give this a try as an interim work around thank you for your input
on 25-10-2021 14:20
I don't think all Asus routers support WAN Balanced aggregation, I think they are possible LACP ~But if yours does.
Of course your starting point is to have the hub 4 in modem mode, (Sorry if being to obvious)
You need to 2 connect to two ports of the hub 4 using a balanced LAGG.
So you are not looking to to increase the overall available through aggregation, simply balancing the load over multiple interfaces. So with multiple parallel connections you will achieve the supplied speed upto 1.14. What you will not get is a single connection greater that 940Mb.
on 26-10-2021 13:53
I was informed we would all be invited to try the new hub. But my trust with virgin is falling hard. Dishonest staff is letting them down.
This is an easy answer for the call centre, we don't know and have no dates as of yet.
Honesty is far better than you'll get invited shortly...
on 28-10-2021 15:15
I spoke to a manager about the Hub 5 today and they advised that no one that is on Gig1 will be getting the hub 5 as a trial. Which leads me to believe that anyone on Gig 1 will not get a free upgrade. Not sure tho...
on 28-10-2021 15:25
I think you may be right and that’s why the outbound team where looking to get people on the 1gig service it’s ashame as a 23 year customer if that is the case.
I have a lead on this within the “pilot team” so I’m just trying to see if I can get lucky.
