Dans_29
How do I do a virgin speed test
I have been getting poor download speeds (around 100mps) that includes on a wired connection and I have m600 fibre.
I have been looking up, and I am advised to do a virgin speed test or “up to speed”, so that a check will be done on my router to see what speeds I should be getting.
My issue is, I can’t find how to do this check anywhere???
I can do standard speed tests and tests using the my speed app, but need the virgin check.
Tags (1)
Stythinator
  • 3.78K
  • 93
  • 340
Problem sorter
Re: How do I do a virgin speed test
Hello,
If you have the Hub 4 then go to https://samknows.com/realspeed/
Dans_29
I have a hub 3 so that doesn’t appear to work. In virgins broadband speed pages, there seems to be an official virgin check. This is what I cannot find.
carl_pearce
  • 1.41K
  • 91
  • 309
Knows their stuff
https://www.virginmedia.com/broadband/speed-test
Andrew-G
  • 10.38K
  • 1.66K
  • 4.74K
If you see 85-100 Mbps by ethernet cable, but get notably better speeds by wifi, then you should try changing the ethernet cable.
Steven_L
  • 10.18K
  • 619
  • 1.06K
Hey @Dans_29,
Welcome back to the community and thanks for taking the time to post here on the forums.
I have been able to locate your account and cannot see any issues from our side, have your services improved since you last posted?
Regards,
Steven_L
