KlausMikalson
How I fixed my slow internet. From 25mbps, to 90mbps, when tech support couldn't help.
Issue started when I restarted router. I got no internet access. I did a factory reset and the internet came back but x2 slower.
A tech came by and messed with a box outside my house. Didn't help.
I replaced router with a new one. Didn't help.
Tech support kept saying that my router settings are ok.
I noticed my default gateway ip address changed after I factory reset. It changed from ipv4(192...) to ipv6 (fe:80:***************). Sometimes it would display both ip's.
The Fix:
I looked up the router gateway setting in the rogers Hitron network management. It was set to DUAL, which is both ipv4 and ipv6.
I tested internet speed on dual setting: 25mbps download, 5mbps upload, 35ms.
Then I changed it to ipv4 only.
Result:
Tested internet on ipv4 only: 90mbps download, 16mbps upload, 10ms. 5ghz: 120mbps download. Instant improvement.
DJ_Shadow1966
  • 7.2K
  • 1.37K
  • 2.06K
Re: How I fixed my slow internet. From 25mbps, to 90mbps, when tech support couldn't help.
Hello
Where are you based as you are posting on a UK based Virginmedia support forum, for Virginmedia UK residential customers who do not use the Hitron router.
Regards Mike
