lthomas88
  • 7
Message 1 of 16
High ping issues
Please see attached my ping results from an external website.
I've tried all fixes such as removing number of devices connected, following the online virgin media fix, etc etc
The ping above is for just one laptop connected to the internet. Admittedly, when doing speed tests this tops 100+mps so isn't an issue, but the constant instability loses connections for video calls, gaming etc etc
This has been am issue for the past week.
Any help and advice is appreciated
Liam
carl_pearce
  • 4.74K
  • 403
  • 707
Superstar
Message 2 of 16
Re: High ping issues
Liam
Create a BQM and post the live link.
Could you access your router using http://192.168.0.1/ or http://192.168.100.1 for modem mode. Log in, select the 'Advanced settings / Tools / Network status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs? Please copy/paste this data as text, split between multiple posts (Sometimes you have to click 'Post' twice due to an error message).
lthomas88
  • 7
Message 3 of 16
Cheers Carl and thanks. see below 🙂 Downstream bonded channels
11390000005.838256 qam1
21470000005.638256 qam2
31550000005.538256 qam3
41630000005.440256 qam4
51710000005.338256 qam5
61790000004.838256 qam6
71870000004.838256 qam7
81950000004.640256 qam8
92030000004.338256 qam9
102110000003.738256 qam10
112190000003.740256 qam11
122270000003.738256 qam12
132350000003.238256 qam13
142430000002.738256 qam14
152510000002.938256 qam15
16259000000340256 qam16
172670000002.238256 qam17
182750000001.238256 qam18
192830000001.438256 qam19
202910000001.740256 qam20
212990000002.238256 qam21
22307000000338256 qam22
233150000003.740256 qam23
243230000003.538256 qam24
1Locked38.911713
2Locked38.912714
3Locked38.911612
4Locked40.31360
5Locked38.916211
6Locked38.91540
7Locked38.916313
8Locked40.3900
9Locked38.913113
10Locked38.91560
11Locked40.318212
12Locked38.917213
13Locked38.92130
14Locked38.93130
15Locked38.925111
16Locked40.32180
17Locked38.93840
18Locked38.98280
19Locked38.99760
20Locked40.364815
21Locked38.64750
22Locked38.93230
23Locked40.32490
24Locked38.92520
lthomas88
  • 7
Message 4 of 16
14620000044512064 qam1
23940000043.5512064 qam2
32580008242.5512064 qam4
43260000043.3512064 qam3
3ATDMA0030
4ATDMA0030
28/01/2021 21:51:16noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/01/2021 21:50:58Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 07:44:9ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2021 14:57:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/01/2021 19:44:7ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 15:51:58criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 12:35:32ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 17:36:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 12:34:51ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 01:29:4noticeSW download Successful - Via NMS
11/01/2021 01:26:9noticeSW Download INIT - Via NMS
09/01/2021 17:28:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2021 23:06:25ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2021 23:06:23ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/01/2021 12:52:6criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/01/2021 03:36:26ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/2021 19:41:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2020 15:36:26ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/12/2020 09:49:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
carl_pearce
  • 4.74K
  • 403
  • 707
Superstar
Message 5 of 16
HUB stats are 'OK'. Power levels not very consistent, but in spec.
Please make sure you create the BQM as it could be congestion.
lthomas88
  • 7
Message 6 of 16
A few questions from a 'noob'
If the HUB stats are just 'OK', how can i improve them?
Power level/spec - how can they become consistant?
BQM???
Your response was super fast. Thanks!
carl_pearce
  • 4.74K
  • 403
  • 707
Superstar
Message 7 of 16
BQM???
You personally can't improve them. There could be an issue with the line.
Again if the line is bad it could explain the power levels.
I asked for a BQM in my original post:
"Create a BQM and post the live link."
The BQM will show line quality and if you are in a congested area.
apcyberax
  • 33.46K
  • 1.87K
  • 5.95K
Message 8 of 16
the hub stats are ok nothing needs changing
carl_pearce
  • 4.74K
  • 403
  • 707
Superstar
Message 9 of 16
Some say the power variation between channels could point to an issue. Not sure myself.
lthomas88
  • 7
Message 10 of 16
I've created a BQM, just unsure what you require from it 🙂
