pmit
  • 14
Message 1 of 23
Hi please help
Im a M500 customer and im only getting on average 90 - 97 mbps
pmit
  • 14
Message 2 of 23
Re: Hi please help
pmit
  • 14
Message 3 of 23
Re: Hi please help
pmit
  • 14
Message 4 of 23
Re: Hi please help
13310000000.938256 qam25
22030000000.738256 qam9
32110000000.538256 qam10
42190000000.538256 qam11
52270000000.538256 qam12
62350000000.538256 qam13
72430000000.438256 qam14
82510000000.538256 qam15
92590000000.238256 qam16
102670000000.438256 qam17
112750000000.438256 qam18
122830000000.538256 qam19
132910000000.238256 qam20
142990000000.538256 qam21
153070000000.238256 qam22
163150000000.738256 qam23
173230000000.538256 qam24
183710000001.238256 qam26
19379000000138256 qam27
20387000000138256 qam28
21395000000138256 qam29
22403000000138256 qam30
234110000000.938256 qam31
244190000000.538256 qam32
1Locked38.940
2Locked38.950
3Locked38.960
4Locked38.960
5Locked38.950
6Locked38.950
7Locked38.930
8Locked38.950
9Locked38.640
10Locked38.640
11Locked38.650
12Locked38.650
13Locked38.960
14Locked38.960
15Locked38.6170
16Locked38.950
17Locked38.900
18Locked38.600
19Locked38.660
20Locked38.650
21Locked38.930
22Locked38.970
23Locked38.670
24Locked38.960
conman33158
  • 804
  • 76
  • 108
Superfast
Message 5 of 23
Re: Hi please help
Are you testing wired or wireless? You need to test with a direct connection with Cat 5e cable or better straight from PC to the Hub using a 1Gbps network card.
pmit
  • 14
Message 6 of 23
Re: Hi please help
I am wired and have cat 5e cables from my pc 2.5G Gigabit Ethernet
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 7 of 23
Re: Hi please help
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 8 of 23
Re: Hi please help
A bit more information is required, please post the following ...
Please do this before posting the Hub Data
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 9 of 23
Re: Hi please help
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Please do not use screen shots.
pmit
  • 14
Message 10 of 23
Re: Hi please help
