22-02-2023 20:09 - edited 22-02-2023 20:10
My broadband is rubbish. It downloads really fast but the connection is really poor for any normal usage. Streaming is patchy, music streaming stops frequently, internet radio cuts out every few minutes. I have a BQM running from thinkbroadband and it looks terrible. I used this when I had Sky Broadband and it looked much less noisy so its something to do with my line. I'm in a FTTP RFoG area. Its been on and off like this for a year.My BQM
Answered! Go to Answer
on 01-03-2023 22:32
I've done a factory reset on my VM Hub 3 and my Asus router tonight. Thats the big red line on the BQM.
on 01-03-2023 23:05
02-03-2023 12:11 - edited 02-03-2023 12:15
I've posted all the daily BQM's since 27th Jan and whilst they were never "great!" they were what I'd expect as it's virgin media but from 12th/13th Feb something changed and the connection went to **bleep**. It was always in modem mode from day of install for about 11 months and it was acceptable. I've only had router mode for 3 days recently and even it got crap within a few days and the spikes when downloading were attrocious even then. What could cause this? I'm getting a bit fed-up with this, can you tell!
on 02-03-2023 12:59
Just typical. It's looking much better already.
I downgraded the asus firmware to a build from 2022 that I had when I last had Sky FTTC without any issues.
So I can only conclude there is an issue with later .386 and .388 firmwares.
on 02-03-2023 21:23
No its getting as bad as before when I checked it just now.
on 02-03-2023 21:52
on 03-03-2023 08:21
Okay. I'm back to router mode from now.
03-03-2023 16:03 - edited 03-03-2023 16:10
Well about 8 hours in and the BQM looks quieter but the internet is still crap. Cannot stream anything for more than a few minutes without it stopping with an access error. The internet stops working when browsing too periodically.
I've disabled the routing functions of the Asus, put them in access point mode for some of the wired devices to connect through. I have moved all wifi and streaming devices to the Hub 3 connections. I aint rewiring the whole house just yet.
on 03-03-2023 16:40
04-03-2023 17:51 - edited 04-03-2023 18:04
The streaming dropping is hopeless and is happening when no other downloading is going on.
It is happening on many devices:
Sonos receiver using Deezer and Amazon Music (wired connection);
and on my Yamaha AV receiver on Internet Radio, Amazon and Deezer (both on wireless and wired connection);
on our Virgin V6 box on iplayer(wired connection);
iplayer watched on my laptop (wifi);
deezer and internet radio on my desktop pc (wired connection);
iplayer on Kodi (wired connection);
iplayer on LG smart tv (wired connection),
music streaming on mobile phones and tablets (wifi);
Additionally since switching over to the Hub 3 streaming media across the LAN from NAS to Kodi and smart tv is unuseable due to the signal dropping every few minutes this didn't occur on the Asus router. I'm left to conclude that the Hub is rubbish and/or there is some other internet problem.
Here's some network log:
04/03/2023 17:59:15 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/03/2023 17:12:46 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
03/03/2023 17:33:19 | notice | NOTICE ATOM is restarted due to Kernel/oops panic as part of Self Healing Mechanism ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
03/03/2023 17:03:30 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
03/03/2023 08:04:34 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:42 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/03/2023 22:02:33 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/03/2023 22:00:19 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/03/2023 21:53:36 | notice | Unit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/02/2023 09:33:35 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/02/2023 00:29:43 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/02/2023 19:33:37 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/02/2023 13:52:26 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/02/2023 11:21:48 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/02/2023 00:42:16 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/02/2023 08:59:25 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/02/2023 07:01:29 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/02/2023 14:01:34 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/02/2023 15:43:16 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/02/2023 13:30:36 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
