22-02-2023 20:09 - edited 22-02-2023 20:10
My broadband is rubbish. It downloads really fast but the connection is really poor for any normal usage. Streaming is patchy, music streaming stops frequently, internet radio cuts out every few minutes. I have a BQM running from thinkbroadband and it looks terrible. I used this when I had Sky Broadband and it looked much less noisy so its something to do with my line. I'm in a FTTP RFoG area. Its been on and off like this for a year.My BQM
Answered! Go to Answer
24-02-2023 17:22 - edited 24-02-2023 17:24
I have two running - this is original asus router now sitting behind hub in router mode
This is the VirginHub in Router mode.
That is the red line around 12.30pm. sorry 2pm.
sorry for any confusion
24-02-2023 17:27 - edited 24-02-2023 17:30
Seem one is spikily the other problem when downloading.
You should connect a PC to the hub in modem mode without a router allow BQM on firewall for a new IP and see what happens then you can use MAC clone option on your router to get that IP or another IP.
Is your Asus Router using Asus firmware? since in modem mode the Asus would be doing the pinging then router mode doing the pinging and might just be the way Asus delay the ping but you connection is fine in modem mode or VM messed up modem mode...
on 25-02-2023 10:26
To be honest, I think I'll just run it in this sub-optimal configuration for now. It has been more stable and functionally it works, streaming is working without glitching. Just need to remember to do full reset of hub every few weeks.
on 25-02-2023 14:36
26-02-2023 12:18 - edited 26-02-2023 12:19
Well, it's not been 2 days yet, and internet radio streaming is starting to glitch again already.
on 26-02-2023 12:26
@legacy1 wrote:Seem one is spikily the other problem when downloading.
To go back to this...
My Router is using the Asus Merlin Firmware - I needed this for previous ISP (Sky) and I like some of the extra features.
So are you saying - Connect PC to Virgin Hub in modem mode. This should force a new IP from Virgin. Then clone this MAC onto Asus Router and run that for abit to see what the BQM does?
If thats what you mean to do then I might try this.
on 26-02-2023 20:16
01-03-2023 09:33 - edited 01-03-2023 09:35
Okay I have just switched back to modem mode and have reverted to default asus firmware on my router.
I have updated the BQM too so it should show connection correctly from 9.30 am.
01-03-2023 10:25 - edited 01-03-2023 11:02
Looking good. or not
Any download or upload you do may show a spike so keep that in mind unless you have setup QoS/BWM right
on 01-03-2023 20:38
It's starting to look a bit rubbish again now.
