boosteruk
  • 5
HUB 4
Since Virgin swapped me top a HUB 4 my speed has reduced by 50% and no device gets wifi any longer has anyone had a similar experience
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: HUB 4
What is your contracted speed ?
What speed do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Can you Login to the Hub Settings and navigate to the Connected Devices page - what does it report the 'connection speed’ as for the cable connected device you used for the speed test ?
boosteruk
  • 5
Re: HUB 4
not a clue how to log into hub settings
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: HUB 4
Hub 4 When the page appears LOG IN then navigate to the Connected Devices page.
