on 20-09-2021 15:20
My Virgin Media fiber connection has been a rock solid 550Mbps for nearly 1 year but for the last 3 days on my wired connection it's just 130Mbps. My phone still gets 550Mbps over a wireless connection (right next to the Hub).
I've tried both a desktop PC and a laptop with a wired connection and gotten near enough the same result so I can rule out my hardware so it must be a problem with the VM Hub's wired connection somewhere?
Any ideas?
Answered! Go to Answer
on 21-09-2021 12:46
Well my hub is giving a stable 550+Mbps over WiFi so it can't be an issue outside of my house, the hub is just having a problem kicking out the same speed over the wired connection even though it's been fine for 10 months. Hopefully the engineer visit on Friday will sort it. My guess is a problem with the hub.
on 21-09-2021 13:59
And strangely my wifi hasn't been that problematic either...My iPhone 8 average (beside Hub) has been around 500 odds over past few months??? My last realsam download to hub/device results on my phone hourly were: 429/460...924/614...401/596...988/590...425/609... 393/485 (Upload always around 50). I wonder if realsam is actually the issue sometimes because if im getting e.g. 401 to the hub then how can i get 596 to the pc?
on 21-09-2021 14:16
@ewhitey wrote:And strangely my wifi hasn't been that problematic either...My iPhone 8 average (beside Hub) has been around 500 odds over past few months??? My last realsam download to hub/device results on my phone hourly were: 429/460...924/614...401/596...988/590...425/609... 393/485 (Upload always around 50). I wonder if realsam is actually the issue sometimes because if im getting e.g. 401 to the hub then how can i get 596 to the pc?
good question - i only have 200 speed but have a hub4 and my speed to the PC is always higher than my speed to the hub using the samknows test - i have just assumed there is actually some overhead in the reading shown to the hub or the test is rubbish - the speed to the hub may or may be of interest but only if the speed at the pc is low
on 21-09-2021 14:19
on 28-09-2021 06:29
SOLVED! I turned out it was a problem my end. For whatever reason I had to reset my network adapter settings on my wired PC. The low speed results I was getting with the wired laptops must have just been a coincidence as they are old laptops.
For reference it's: Windows Start Menu/Settings/Network & Internet/Network Reset
Just to add for anyone else trying to diagnose exactly what part of a network is causing speed issues, it's worth buying an Ethernet to USB-C (or whatever USB your mobile phone has) for about £10 from the Rainforest. As it essentially turns your phone into a network speed meter.
I bought a USB-C 1Gbps one and I use the Ookla speed test app so now I can just plug it into any port or ethernet cable that's connected to the internet and it'll do a speed test. By process of elimination I can now narrow down what's at fault. If I'd have had that a week ago I would have avoided having to take a day off work and wait around for 4hrs for a VM engineer to come out.
