Daveycoder
  • 31
Message 1 of 7
Good speed on broadband speed checker, bad when downloading
I've a really strange problem - using the internet normally, zoom calls etc, are all fine - the broadband speed checker is showing good rates. However, whenever I try and download from certain sites (e.g. EA or Corsair) I end up with a download speed of around 26kb (yes, kb!) per second. This only seems to happen on some sites, and mainly gaming sites! I can play okay, but download speeds are horrific.
I've also a 2nd (much slower) line with a different provider (for work use), and swapping over to that is the only way I can download at a decent speed (well, better than 26kb - 5mb/s instead) - I'm mentioning this as swapping over eliminated the PC as being the issue.
So I'm left with a situation where I can't download from sites using VM but can with a different connection!
Is this VM "throttling" me from sites, or something else wrong? FWIW, here's my info...
Item Status Comments
299000000
Locked
Ranged Upstream Channel (Hz)
60300044
Locked
Provisioning State
Online
12990000001.235256 qam21
22510000000.235256 qam15
3259000000035256 qam16
4267000000-0.235256 qam17
52750000000.235256 qam18
62830000000.535256 qam19
72910000000.935256 qam20
83070000001.236256 qam22
9315000000136256 qam23
103230000001.737256 qam24
113470000001.737256 qam25
123550000001.937256 qam26
13363000000237256 qam27
14371000000237256 qam28
153790000001.437256 qam29
16387000000137256 qam30
17395000000137256 qam31
184030000000.737256 qam32
194110000000.737256 qam33
204190000000.437256 qam34
214270000000.437256 qam35
224350000000.537256 qam36
234430000000.537256 qam37
244510000000.537256 qam38
Daveycoder
  • 31
Message 2 of 7
Re: Good speed on broadband speed checker, bad when downloading
1Locked35.718738782916
2Locked35.741621642203
3Locked35.72301808285118
4Locked359892553456595
5Locked35.5399314466702
6Locked35.7124810673411
7Locked35.523681269237
8Locked36.31581928279
9Locked36.61091456650
10Locked37.3293949299
11Locked37.3218198787
12Locked37.3147825928
13Locked37.3132784019
14Locked37.3118028072
15Locked37.3140624864
16Locked37.3130319914
17Locked37.6229587269
18Locked37.3134095274
19Locked37.62125632177
20Locked37.3116257259
21Locked37.3126587421
22Locked37.3135526417
23Locked37.6108537752
24Locked37.31071110224
16030004450.8512064 qam4
24620000049.3512064 qam6
35370004449.5512064 qam5
43940000048.5512064 qam9
1ATDMA0020
2ATDMA0040
3ATDMA0040
4ATDMA0050
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060-b.cm
Daveycoder
  • 31
Message 3 of 7
SFID396660
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID396659
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
16/05/2021 11:55:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/05/2021 20:36:30ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/05/2021 06:06:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/05/2021 12:34:30Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/05/2021 08:36:30ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/05/2021 16:56:53criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2021 20:36:30ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2021 00:55:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2021 08:36:30ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/04/2021 00:56:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2021 20:36:30ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2021 06:05:17criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2021 03:28:31Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2021 14:22:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2021 08:36:30ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2021 05:51:20Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/04/2021 19:26:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/04/2021 17:53:15ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/04/2021 10:13:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/04/2021 13:47:23Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
conman33158
  • 1.67K
  • 134
  • 364
Super solver
Message 4 of 7
You have a lot of Post RS Errors and T3 Timeouts plus your upload stream power levels are sitting a bit high. This could indicate a fault or could be errors from a previous fault.
Have you tried a full factory reset and see how quickly the errors rise again if at all? Hold in the pinhole at the rear of the router for at least 50 seconds and then release (the lights will flash while holding in the pinhole reset button after about 10-15 seconds) then allow 5 minutes for the router to reboot and re-sync the connection.
Please ensure that your WiFi network password is still readable on the Hub sticker before you do this or that you at least have a copy of your original network password 🙂
BT Full Fibre 900 FTTP - Asus RT-AX82U to Openreach ONT Box & Asus RT-AX56U with AiMesh setup
Emily_G
  • 4.82K
  • 209
  • 289
Message 5 of 7
Thanks for the post Daveycoder.
We can see that the Hub could use a pin hole reset, can you please try this and let us know how it goes.
Thanks, Emily.
Daveycoder
  • 31
Message 6 of 7
Hi - Apologies for the delay in replying.
I did the pin reset, and am happy to report that I've no errors in my log any more, and I can actually download again at decent speeds!
So everythings working again, and I'm happy. 🙂
Thanks all for your help.
Zak_M
  • 6.12K
  • 315
  • 544
Message 7 of 7
Thank you for coming back to us @Daveycoder
Really glad to hear things are shaping up well.
Please do keep an eye on things and do let us know if things take a turn for the worse.
Kind regards,
Zak_M
