on 13-10-2021 09:51
I've had Gig1 installed yesterday & since then my download is 600mb at a push on WiFi & wired in modem mode, when before on 600mb ultimate oomph package I got 650mb on both WiFi & wired in modem mode using my Asus ax11000 router. I have cat7 ethernet cables running from hub4 to the Asus router & still the maximum speed I'm getting is 600mb download & 51mb upload? Can anyone help?
Answered! Go to Answer
on 14-10-2021 11:08
ok you are on 1gig but theres more to it than that - does the area have 1 gig
post the other pages from the router
log into hub3/4 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labelled - upstream - downstream
on 15-10-2021 13:19
Thats all I have. Any ideas? Surely I wifi 6 router with 2. 5gb ethernet port can get full 1gig speed from hub 4 in modem mode?
on 15-10-2021 14:14
on 15-10-2021 15:40
Yes it says 1 docsis 3.1 channel & 31 docsis 3.0 channels.
on 15-10-2021 15:44
hard to read but from what i can see levels look ok
try a full reset see if that helps and try a sped test with a wired pc direct to the hub with the hub in modem mode
on 15-10-2021 15:47
done a speed test 634mb download 52mb upload and thats with a cat 7 ethernet on an msi gaming laptop with wifi 6 and 10gb port. still same speeds i had before i upgraded only the upload has increased.
on 15-10-2021 15:50
3.0 Downstream channels
25 | 330750000 | 7.599998 | 40.366287 | QAM256 | 25 |
1 | 138750000 | 8.800003 | 40.366287 | QAM256 | 1 |
2 | 146750000 | 8.800003 | 40.366287 | QAM256 | 2 |
3 | 154750000 | 8.800003 | 40.946209 | QAM256 | 3 |
4 | 162750000 | 8.500000 | 40.366287 | QAM256 | 4 |
5 | 170750000 | 8.300003 | 40.366287 | QAM256 | 5 |
6 | 178750000 | 8.199997 | 40.366287 | QAM256 | 6 |
7 | 186750000 | 8.199997 | 40.946209 | QAM256 | 7 |
8 | 194750000 | 8.300003 | 40.366287 | QAM256 | 8 |
9 | 202750000 | 8.300003 | 40.366287 | QAM256 | 9 |
10 | 210750000 | 8.400002 | 40.366287 | QAM256 | 10 |
11 | 218750000 | 8.400002 | 40.366287 | QAM256 | 11 |
12 | 226750000 | 8.400002 | 40.366287 | QAM256 | 12 |
13 | 234750000 | 8.300003 | 40.946209 | QAM256 | 13 |
14 | 242750000 | 8.500000 | 40.366287 | QAM256 | 14 |
15 | 250750000 | 8.500000 | 40.946209 | QAM256 | 15 |
16 | 258750000 | 8.800003 | 40.366287 | QAM256 | 16 |
17 | 266750000 | 9.000000 | 40.366287 | QAM256 | 17 |
18 | 274750000 | 9.300003 | 40.946209 | QAM256 | 18 |
19 | 282750000 | 9.400002 | 40.366287 | QAM256 | 19 |
20 | 290750000 | 9.199997 | 40.366287 | QAM256 | 20 |
21 | 298750000 | 9.000000 | 40.366287 | QAM256 | 21 |
22 | 306750000 | 8.400002 | 40.366287 | QAM256 | 22 |
23 | 314750000 | 8.099998 | 40.366287 | QAM256 | 23 |
24 | 322750000 | 7.800003 | 40.366287 | QAM256 | 24 |
26 | 338750000 | 7.099998 | 40.366287 | QAM256 | 26 |
27 | 346750000 | 7.000000 | 40.366287 | QAM256 | 27 |
28 | 354750000 | 7.800003 | 40.946209 | QAM256 | 28 |
29 | 362750000 | 7.800003 | 40.366287 | QAM256 | 29 |
30 | 370750000 | 8.099998 | 40.366287 | QAM256 | 30 |
31 | 378750000 | 8.099998 | 40.946209 | QAM256 | 31 |
25 | Locked | 40.366287 | 0 | 0 |
1 | Locked | 40.366287 | 0 | 0 |
2 | Locked | 40.366287 | 0 | 0 |
3 | Locked | 40.946209 | 0 | 0 |
4 | Locked | 40.366287 | 0 | 0 |
6 | Locked | 40.366287 | 0 | 0 |
7 | Locked | 40.946209 | 0 | 0 |
8 | Locked | 40.366287 | 0 | 0 |
9 | Locked | 40.366287 | 0 | 0 |
10 | Locked | 40.366287 | 0 | 0 |
11 | Locked | 40.366287 | 0 | 0 |
12 | Locked | 40.366287 | 0 | 0 |
13 | Locked | 40.946209 | 0 | 0 |
14 | Locked | 40.366287 | 0 | 0 |
15 | Locked | 40.946209 | 0 | 0 |
16 | Locked | 40.366287 | 0 | 0 |
17 | Locked | 40.366287 | 0 | 0 |
18 | Locked | 40.946209 | 0 | 0 |
19 | Locked | 40.366287 | 0 | 0 |
20 | Locked | 40.366287 | 0 | 0 |
21 | Locked | 40.366287 | 0 | 0 |
22 | Locked | 40.366287 | 0 | 0 |
23 | Locked | 40.366287 | 0 | 0 |
24 | Locked | 40.366287 | 0 | 0 |
26 | Locked | 40.366287 | 0 | 0 |
27 | Locked | 40.366287 | 0 | 0 |
28 | Locked | 40.946209 | 0 | 0 |
29 | Locked | 40.366287 | 0 | 0 |
30 | Locked | 40.366287 | 0 | 0 |
31 | Locked | 40.946209 | 0 | 0 |
33 | 94 | 4K | 1840 | QAM4096 | 416 |
33 | Locked | 43 | 8.0 | 75883154 | 0 |
on 15-10-2021 15:51
3.0 Upstream channels
1 | 53700000 | 48.270599 | 5120 KSym/sec | 64QAM | 2 |
2 | 39400000 | 48.020599 | 5120 KSym/sec | 64QAM | 4 |
3 | 60300000 | 47.770599 | 5120 KSym/sec | 64QAM | 1 |
4 | 46200000 | 48.270599 | 5120 KSym/sec | 64QAM | 3 |
1 | US_TYPE_STDMA | 0 | 0 | 1 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
on 15-10-2021 18:01
Any help?
on 15-10-2021 18:18
