on 20-05-2022 16:40
I've been upgraded to Gig1 today. On M500 I was very happy with a very consistent 500 down. Now on Gig1 I'm experiencing around 220 down.
On M500 I was running in Modem mode, I've tried both Modem mode and Router mode and both get the same results.
My last samknows test:
I've tried reboots, factory resets etc.
After reading similar threads it looks like something could be wrong with the 3.1 channels on my line. I'll post the status info below.
on 20-05-2022 16:41
1 | 411000000 | -3.4 | 37.6 | QAM256 | 1 |
2 | 419000000 | -4.2 | 36.6 | QAM256 | 2 |
3 | 427000000 | -4.2 | 37.6 | QAM256 | 3 |
4 | 435000000 | -7.2 | 36.4 | QAM256 | 4 |
5 | 443000000 | -6.1 | 33.8 | QAM256 | 5 |
6 | 451000000 | -9.2 | 36.4 | QAM256 | 6 |
7 | 459000000 | -9 | 36.4 | QAM256 | 7 |
8 | 467000000 | -7.7 | 36.6 | QAM256 | 8 |
9 | 475000000 | -7 | 37.6 | QAM256 | 9 |
10 | 483000000 | -4 | 37.6 | QAM256 | 10 |
11 | 491000000 | -4.3 | 37.6 | QAM256 | 11 |
12 | 499000000 | -2.7 | 38.6 | QAM256 | 12 |
13 | 507000000 | -2.5 | 37.6 | QAM256 | 13 |
14 | 515000000 | -2.3 | 37.6 | QAM256 | 14 |
15 | 523000000 | -2.1 | 37.6 | QAM256 | 15 |
16 | 531000000 | -1.5 | 38.6 | QAM256 | 16 |
17 | 539000000 | 0.2 | 38.6 | QAM256 | 17 |
18 | 547000000 | -0.2 | 38.6 | QAM256 | 18 |
19 | 555000000 | 0.4 | 38.6 | QAM256 | 19 |
20 | 563000000 | -0.8 | 38.6 | QAM256 | 20 |
21 | 571000000 | -1.4 | 37.6 | QAM256 | 21 |
22 | 579000000 | -2.2 | 37.6 | QAM256 | 22 |
23 | 587000000 | -2.6 | 37.6 | QAM256 | 23 |
24 | 595000000 | -2.6 | 37.6 | QAM256 | 24 |
25 | 603000000 | -3.1 | 37.6 | QAM256 | 25 |
26 | 611000000 | -1.2 | 37.6 | QAM256 | 26 |
27 | 619000000 | -1.2 | 37.6 | QAM256 | 27 |
28 | 627000000 | -0.6 | 37.4 | QAM256 | 28 |
29 | 635000000 | -2.1 | 37.6 | QAM256 | 29 |
30 | 643000000 | -0.9 | 37.6 | QAM256 | 30 |
31 | 651000000 | -0.1 | 37.4 | QAM256 | 31 |
1 | Locked | 37.636276 | 0 | 0 |
2 | Locked | 36.609653 | 0 | 0 |
3 | Locked | 37.636276 | 921 | 0 |
4 | Locked | 36.386890 | 1875006 | 0 |
5 | Locked | 33.834164 | 4258138 | 152214 |
6 | Locked | 36.386890 | 2 | 0 |
7 | Locked | 36.386890 | 0 | 0 |
8 | Locked | 36.609653 | 819585 | 0 |
9 | Locked | 37.636276 | 4 | 0 |
10 | Locked | 37.636276 | 77 | 0 |
11 | Locked | 37.636276 | 4234 | 0 |
12 | Locked | 38.605377 | 0 | 0 |
13 | Locked | 37.636276 | 0 | 0 |
14 | Locked | 37.636276 | 0 | 0 |
15 | Locked | 37.636276 | 0 | 0 |
16 | Locked | 38.605377 | 0 | 0 |
17 | Locked | 38.605377 | 1 | 0 |
18 | Locked | 38.605377 | 0 | 0 |
19 | Locked | 38.605377 | 0 | 0 |
20 | Locked | 38.605377 | 0 | 0 |
21 | Locked | 37.636276 | 0 | 0 |
22 | Locked | 37.636276 | 0 | 0 |
23 | Locked | 37.636276 | 0 | 0 |
24 | Locked | 37.636276 | 0 | 0 |
25 | Locked | 37.636276 | 0 | 0 |
26 | Locked | 37.636276 | 0 | 0 |
27 | Locked | 37.636276 | 1 | 0 |
28 | Locked | 37.355988 | 0 | 0 |
29 | Locked | 37.636276 | 0 | 0 |
30 | Locked | 37.636276 | 0 | 0 |
31 | Locked | 37.355988 | 1 | 0 |
33 | 96 | 4K | 1880 | QAM4096 | 759 |
33 | Locked | 38 | -6.5 | 7962775 | 11 |
on 21-05-2022 11:45
on 22-05-2022 12:35
I doubled checked the connectors and they all seemed good. The power levels still look to be jumping up and down, I'll post them below.
Did another 90 second reset on the hub today and still seeing the same results. Last SamKnows test was 229 to the hub.
1 | 411000000 | -2.9 | 37.6 | QAM256 | 1 |
2 | 419000000 | -3.6 | 37.4 | QAM256 | 2 |
3 | 427000000 | -3.6 | 37.6 | QAM256 | 3 |
4 | 435000000 | -6.4 | 36.6 | QAM256 | 4 |
5 | 443000000 | -5.3 | 34.9 | QAM256 | 5 |
6 | 451000000 | -8.5 | 36.6 | QAM256 | 6 |
7 | 459000000 | -8.4 | 36.4 | QAM256 | 7 |
8 | 467000000 | -8.2 | 33.4 | QAM256 | 8 |
9 | 475000000 | -8 | 37.4 | QAM256 | 9 |
10 | 483000000 | -4.5 | 37.6 | QAM256 | 10 |
11 | 491000000 | -4.7 | 37.4 | QAM256 | 11 |
12 | 499000000 | -3 | 37.6 | QAM256 | 12 |
13 | 507000000 | -2.7 | 37.6 | QAM256 | 13 |
14 | 515000000 | -2.5 | 37.6 | QAM256 | 14 |
15 | 523000000 | -2.3 | 37.6 | QAM256 | 15 |
16 | 531000000 | -1.7 | 37.6 | QAM256 | 16 |
20 | 563000000 | -0.9 | 37.6 | QAM256 | 20 |
21 | 571000000 | -1.5 | 37.6 | QAM256 | 21 |
22 | 579000000 | -2.3 | 37.4 | QAM256 | 22 |
24 | 595000000 | -2.6 | 37.4 | QAM256 | 24 |
25 | 603000000 | -3 | 37.6 | QAM256 | 25 |
26 | 611000000 | -1.1 | 37.6 | QAM256 | 26 |
28 | 627000000 | -0.6 | 37.6 | QAM256 | 28 |
30 | 643000000 | -0.8 | 37.6 | QAM256 | 30 |
31 | 651000000 | 0 | 37.6 | QAM256 | 31 |
2 | Locked | 37.355988 | 0 | 0 |
3 | Locked | 37.636276 | 29 | 0 |
4 | Locked | 36.609653 | 104659 | 0 |
5 | Locked | 34.925610 | 374664 | 24855 |
6 | Locked | 36.609653 | 0 | 0 |
7 | Locked | 36.386890 | 145 | 0 |
8 | Locked | 33.376591 | 819077 | 41790 |
9 | Locked | 37.355988 | 132 | 0 |
10 | Locked | 37.636276 | 427 | 0 |
11 | Locked | 37.355988 | 945 | 0 |
12 | Locked | 37.636276 | 0 | 0 |
16 | Locked | 37.636276 | 0 | 0 |
17 | Locked | 38.605377 | 0 | 0 |
20 | Locked | 37.636276 | 0 | 0 |
22 | Locked | 37.355988 | 0 | 0 |
24 | Locked | 37.355988 | 0 | 0 |
27 | Locked | 37.636276 | 0 | 0 |
28 | Locked | 37.636276 | 0 | 0 |
31 | Locked | 37.636276 | 0 | 0 |
on 22-05-2022 13:17
Hi @Bowiiee
Welcome to the community
Sorry to hear you're having issues with your broadband at this time. On checking our systems, I can see that you do have issues with your power levels as well as other levels out of spec. Please join me on private message so I can locate your account and book you an engineer to investigate further. You can see your private messages at the top of the page, in the envelope icon.
on 22-05-2022 14:25
Thanks so much for your private message @Bowiiee, I have now booked you a visit for your broadband issue – you can check the date and time via your online account here. If you have any issues with accessing your online account or unable to see your visit, please do let us know and we’ll pop you a message to confirm.
There will be no charge for this visit unless:
• The technician diagnoses the faults as not being caused by our network/equipment
• The technician discovers that the fault or problem relates to your equipment
• The technician discovers that the fault or problem relates to any system that we are not responsible for
The technician will confirm during their visit if any of these instances apply, and if so, a £25 charge will be applied to your account.
Please ensure there is someone over the age of 18 present at the time of the visit. If you need to change or cancel your appointment you can do this online or via the MyVM app by 4pm the day before the appointment.
If you do miss an agreed appointment for any reason, a £25 missed appointment charge will be applied to your account on the day of the appointment.
