on 07-09-2021 20:40
Hi all, hope someone can help.
I upgraded from M350 to Gig1 Fibre Broadband a few weeks ago but I'm not getting the speeds I thought I would. I'm getting around 400-500Mbps on a wired connection in modem mode.
Now *I think* it might be because of my current setup at home. I currently have my VM Hub 4 in Modem Mode downstairs with a CAT6 cable running around 5 meters or so to a TaoTronics Mesh Wi-Fi Router which is placed directly below my bedroom which is then connected to another TaoTronics Mesh Wi-Fi 'node' upstairs in my bedroom by wireless. This one in my bedroom is then connected by Ethernet to my Computer and PS5. I assume because of this I wont be getting the best of speeds? I know on the M350 package I was receiving full speeds with this setup.
The problem is that as my Computer is upstairs I cant test directly to the VM Hub 4 to see if I am receiving the Gig1 and I don't have any laptop to test this. I guess the only way would be to take my PS5 downstairs but unsure if this will display the correct speeds.
Although I had a look at my Hub 4 stats and I don't think they look quite right. I will post them here and see what you think.
Cable Modem StatusItem Status CommentsChannel Overview Downstream Upstream
Cable Modem Status | Online | DOCSIS 3.1 |
Primary downstream channel | Locked | SC-QAM |
DOCSIS 3.0 channels | 31 | 4 |
DOCSIS 3.1 channels | 1 | 0 |
on 09-09-2021 11:42
Hi @John_GS,
Thank you again for sorting that out for me, hopefully it will be better after the visit. I will keep you updated.
on 10-09-2021 15:00
So engineer visited today, changed some wires etc. and had a look at the power spec which has been altered and I'm still receiving the same kind of speeds.
Now I purchased a Wifi 6 router yesterday (ASUS ZenWifi AX XT8), set it up last night and I was receiving much better speeds than I am now. On Fast.com and Testmynet the speeds were around 800+ sometimes hitting 900+ on ethernet and around 500 on wifi. On my PS5 I was hitting 800+. Speedtest.net was displaying only 500 on my computer and phone though but I'm sure this was incorrect.
Tbh I should have cancelled the engineer visit but thought it might be worth him coming over to alter the power etc.
I've been told by the engineer that the wire outside going into my house needs changing which has been booked in for 27.09. I'm hoping this will sort it out.
I've checked the stats again and the power levels look good to me although the QAM 3.1 Downstream channels profile looks to be worse? Remember I was on QAM2048? Its now set at QAM256 which I believe its the wrong one! I will update with the new stats below.
on 10-09-2021 15:01
3.0 Downstream channels
29 | 363000000 | 3.500000 | 40.366287 | QAM256 | 29 |
32 | 387000000 | 2.900002 | 38.983261 | QAM256 | 32 |
33 | 395000000 | 2.400002 | 38.983261 | QAM256 | 33 |
34 | 403000000 | 1.900002 | 38.605377 | QAM256 | 34 |
4 | 163000000 | 10.900002 | 40.366287 | QAM256 | 4 |
5 | 171000000 | 10.199997 | 40.366287 | QAM256 | 5 |
6 | 179000000 | 9.800003 | 40.366287 | QAM256 | 6 |
7 | 187000000 | 9.500000 | 40.366287 | QAM256 | 7 |
8 | 195000000 | 9.199997 | 40.946209 | QAM256 | 8 |
9 | 203000000 | 9.000000 | 40.946209 | QAM256 | 9 |
10 | 211000000 | 8.800003 | 40.366287 | QAM256 | 10 |
11 | 219000000 | 8.500000 | 40.946209 | QAM256 | 11 |
12 | 227000000 | 8.199997 | 40.946209 | QAM256 | 12 |
13 | 235000000 | 7.800003 | 40.946209 | QAM256 | 13 |
14 | 243000000 | 7.800003 | 40.946209 | QAM256 | 14 |
15 | 251000000 | 8.000000 | 40.946209 | QAM256 | 15 |
16 | 259000000 | 8.300003 | 40.946209 | QAM256 | 16 |
17 | 267000000 | 8.000000 | 40.366287 | QAM256 | 17 |
18 | 275000000 | 7.400002 | 40.946209 | QAM256 | 18 |
19 | 283000000 | 7.000000 | 40.366287 | QAM256 | 19 |
20 | 291000000 | 6.500000 | 40.946209 | QAM256 | 20 |
21 | 299000000 | 6.199997 | 40.366287 | QAM256 | 21 |
22 | 307000000 | 6.300003 | 40.946209 | QAM256 | 22 |
23 | 315000000 | 6.099998 | 40.946209 | QAM256 | 23 |
24 | 323000000 | 5.800003 | 40.366287 | QAM256 | 24 |
25 | 331000000 | 5.000000 | 40.366287 | QAM256 | 25 |
26 | 339000000 | 4.400002 | 40.366287 | QAM256 | 26 |
27 | 347000000 | 3.900002 | 40.366287 | QAM256 | 27 |
28 | 355000000 | 3.599998 | 38.605377 | QAM256 | 28 |
30 | 371000000 | 3.400002 | 40.366287 | QAM256 | 30 |
31 | 379000000 | 3.200001 | 40.366287 | QAM256 | 31 |
29 | Locked | 40.366287 | 0 | 0 |
32 | Locked | 38.983261 | 0 | 0 |
33 | Locked | 38.983261 | 5 | 0 |
34 | Locked | 38.605377 | 0 | 0 |
4 | Locked | 40.366287 | 0 | 0 |
5 | Locked | 40.366287 | 0 | 0 |
6 | Locked | 40.366287 | 0 | 0 |
7 | Locked | 40.366287 | 0 | 0 |
8 | Locked | 40.946209 | 0 | 0 |
9 | Locked | 40.946209 | 0 | 0 |
10 | Locked | 40.366287 | 0 | 0 |
11 | Locked | 40.946209 | 0 | 0 |
12 | Locked | 40.946209 | 7 | 0 |
13 | Locked | 40.946209 | 0 | 0 |
14 | Locked | 40.946209 | 0 | 0 |
15 | Locked | 40.946209 | 0 | 0 |
16 | Locked | 40.946209 | 0 | 0 |
17 | Locked | 40.366287 | 6 | 0 |
18 | Locked | 40.946209 | 0 | 0 |
19 | Locked | 40.366287 | 0 | 0 |
20 | Locked | 40.946209 | 0 | 0 |
21 | Locked | 40.366287 | 0 | 0 |
22 | Locked | 40.946209 | 0 | 0 |
23 | Locked | 40.946209 | 8 | 0 |
24 | Locked | 40.366287 | 0 | 0 |
25 | Locked | 40.366287 | 0 | 0 |
26 | Locked | 40.366287 | 0 | 0 |
27 | Locked | 40.366287 | 0 | 0 |
28 | Locked | 38.605377 | 0 | 0 |
30 | Locked | 40.366287 | 0 | 0 |
31 | Locked | 40.366287 | 0 | 0 |
159 | 96 | 4K | 1880 | QAM256 | 759 |
159 | Locked | 36 | -6.1 | 12 | 0 |
on 10-09-2021 15:02
3.0 Upstream channels
1 | 60300000 | 45.020599 | 5120 KSym/sec | 64QAM | 9 |
2 | 39400000 | 41.770599 | 5120 KSym/sec | 64QAM | 12 |
3 | 46200000 | 43.270599 | 5120 KSym/sec | 64QAM | 11 |
4 | 53700000 | 44.270599 | 5120 KSym/sec | 64QAM | 10 |
1 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
General Configuration
Network access | true |
Maximum Number of CPEs | 1 |
Baseline Privacy | true |
DOCSIS Mode | 3.1 |
Config file | wrkldJKDHSUBsgvca69834ncxv987 |
SFID | 2488 |
Max Traffic Rate | 1200000450 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
Primary Upstream Service Flow
SFID | 236 |
Max Traffic Rate | 55000270 |
Max Concatenated Burst | 16320 |
Scheduling Type | bestEffort |
on 10-09-2021 15:06
on 10-09-2021 15:11
Yeah I thought so! I guess its either book another engineer out to visit or wait for him to come over on the 27/09! Ideally I would like an engineer over sooner rather than later.
@John_GS I wonder if you could try and sort our another engineer visit to sort out my 3.1 channel please?
on 10-09-2021 18:27
Wow that 3.1 channel got worse.
Also the power levels on your 3.0 channels are between 1.9 and 10.9. Thats too much difference.
On top of that two of those channels are over the limit if 10
on 10-09-2021 19:50
So I noticed at the back of the Hub4 he has fitted a teleste ash-gisx101 (galvanic isolator) which I've never had before. I've removed this and reset the hub4 back to default settings and the power levels on the 3.0 channel look to be far too high (2 are at 10, another 2 at 11 and one at 12!!!).
The 3.1 channel was at QAM256 before I set it to Modem Mode which is now displaying QAM2048 but it seems to change whenever the hub restarts or after a few hours of up time. I saw it at QAM1024 as well as QAM512 earlier. I presume this should never happen and should always be set permanently at QAM4096. Does anyone know how the engineer changes this type of profile? He told me that the QAM is an area type thing, surely this cant be right?!
Thanks for all the help everyone, I think I need another engineer to come out!
on 13-09-2021 12:03
Hey @Jmste,
Thanks for the updates, I'm very sorry that the issue has persisted.
As our engineering team has identified a cabling issue and booked in the job to fix this, we would not be able to book another visit in the meantime.
Apologies that an earlier appointment has not been available for this but our team are working to resolve these issues you are experiencing.
If you do require any further support following this then please do reach out.
Kind regards,
