on 19-11-2021 00:22
Hi I recently upgraded from M350 to Gig 1 fiber broadband and every time I do an interment speed test I seem to be hitting the speed of the M350. I am not even close to the minimum speed of Gig 1 fiber. I have included my router status page in case somebody can tell me something from that.
19-11-2021 09:18 - edited 19-11-2021 09:19
Go to www.samknows.com/realspeed and post what that shows please.
on 19-11-2021 10:01
19-11-2021 10:06 - edited 19-11-2021 10:07
Your config is correct for 1GB. Primary Downstream Service Flow is the one you need to check and it is set for 1GB.
As @BenMcr states what does SamKnows report as speed to the Hub.?
Also speed test should be done wired directly to the Hub with a known good Cat 6 cable.
19-11-2021 10:33 - edited 19-11-2021 10:34
@HZR_Kairos wrote:
Something needs looking at based on that test.
on 21-11-2021 12:13
Hello HZR_Kairos
Thanks for your post
How are thigs looking now
I have been able to run a Sam knows speed test from here and the speed to the hub is just over 1GB
Gareth_L
on 21-11-2021 12:23
Everything is fine now, when I called virgin media he told to hold down the reset button; it rebooted and and now works fine.I’m not sure how to close the request
on 23-11-2021 12:55
Hi HZR_Kairos
Can you please explain the Request
Sorry to ask, bit unsure what it is you are referring to
Gareth_L
