on 24-06-2022 16:04
Hi folks,
1/2
Virgin recently resolved the severe evening congestion problems. However, we're now encountering intermittent drop-outs and upload performance problems. It's a real pain, as I lose my connectivity to company network.
The graph looks ok other than some latency spikiness:
I'm also pasting stats and log. Anything obvious amiss?
Cable Modem Status | ||
Item | Status | Comments |
Cable Modem Status | Online | DOCSIS 3.1 |
Primary downstream channel | Locked | SC-QAM |
Channel Overview | Downstream | Upstream |
DOCSIS 3.0 channels | 31 | 4 |
DOCSIS 3.1 channels | 1 | 0 |
3.0 Downstream channels
Channel | Frequency (Hz) | Power (dBmV) | SNR (dB) | Modulation | Channel ID |
29 | 363000000 | 4.2 | 37.4 | QAM256 | 29 |
1 | 139000000 | 6 | 33.4 | QAM256 | 1 |
2 | 147000000 | 5.8 | 33.8 | QAM256 | 2 |
3 | 155000000 | 5.5 | 34 | QAM256 | 3 |
4 | 163000000 | 5.2 | 34.5 | QAM256 | 4 |
5 | 171000000 | 4.8 | 34.5 | QAM256 | 5 |
6 | 179000000 | 4.6 | 34.9 | QAM256 | 6 |
7 | 187000000 | 4.6 | 35.1 | QAM256 | 7 |
8 | 195000000 | 4.6 | 35.8 | QAM256 | 8 |
9 | 203000000 | 4.5 | 35.6 | QAM256 | 9 |
10 | 211000000 | 4.5 | 36.4 | QAM256 | 10 |
11 | 219000000 | 4.4 | 36.4 | QAM256 | 11 |
12 | 227000000 | 4.7 | 36.6 | QAM256 | 12 |
13 | 235000000 | 4.9 | 36.4 | QAM256 | 13 |
14 | 243000000 | 5.1 | 36.6 | QAM256 | 14 |
15 | 251000000 | 5.1 | 37.4 | QAM256 | 15 |
16 | 259000000 | 5.2 | 37.4 | QAM256 | 16 |
17 | 267000000 | 5 | 37.4 | QAM256 | 17 |
18 | 275000000 | 4.9 | 37.4 | QAM256 | 18 |
19 | 283000000 | 4.9 | 37.6 | QAM256 | 19 |
20 | 291000000 | 5.1 | 37.6 | QAM256 | 20 |
21 | 299000000 | 5 | 37.6 | QAM256 | 21 |
22 | 307000000 | 4.6 | 37.4 | QAM256 | 22 |
23 | 315000000 | 4.4 | 37.6 | QAM256 | 23 |
24 | 323000000 | 4 | 37.6 | QAM256 | 24 |
25 | 331000000 | 4.1 | 37.4 | QAM256 | 25 |
26 | 339000000 | 4.2 | 37.4 | QAM256 | 26 |
27 | 347000000 | 4.1 | 37.6 | QAM256 | 27 |
28 | 355000000 | 4.2 | 37.6 | QAM256 | 28 |
30 | 371000000 | 4.3 | 37.4 | QAM256 | 30 |
31 | 379000000 | 4.2 | 37.6 | QAM256 | 31 |
on 24-06-2022 16:05
2/2
Channel | Lock Status | RxMER (dB) | Pre RS Errors | Post RS Errors |
29 | Locked | 37.355988 | 0 | 0 |
1 | Locked | 33.376591 | 717 | 0 |
2 | Locked | 33.834164 | 321 | 0 |
3 | Locked | 33.956509 | 99 | 0 |
4 | Locked | 34.483570 | 56 | 0 |
5 | Locked | 34.483570 | 34 | 0 |
6 | Locked | 34.925610 | 16 | 0 |
7 | Locked | 35.083549 | 4 | 0 |
8 | Locked | 35.779911 | 0 | 0 |
9 | Locked | 35.595078 | 1 | 0 |
10 | Locked | 36.386890 | 2 | 0 |
11 | Locked | 36.386890 | 0 | 0 |
12 | Locked | 36.609653 | 0 | 0 |
13 | Locked | 36.386890 | 0 | 0 |
14 | Locked | 36.609653 | 0 | 0 |
15 | Locked | 37.355988 | 0 | 0 |
16 | Locked | 37.355988 | 0 | 0 |
17 | Locked | 37.355988 | 0 | 0 |
18 | Locked | 37.355988 | 0 | 0 |
19 | Locked | 37.636276 | 0 | 0 |
20 | Locked | 37.636276 | 0 | 0 |
21 | Locked | 37.636276 | 0 | 0 |
22 | Locked | 37.355988 | 0 | 0 |
23 | Locked | 37.636276 | 0 | 0 |
24 | Locked | 37.636276 | 0 | 0 |
25 | Locked | 37.355988 | 0 | 0 |
26 | Locked | 37.355988 | 0 | 0 |
27 | Locked | 37.636276 | 0 | 0 |
28 | Locked | 37.636276 | 0 | 0 |
30 | Locked | 37.355988 | 0 | 0 |
31 | Locked | 37.636276 | 0 | 0 |
3.1 Downstream channels
Channel | Channel Width (MHz) | FFT Type | Number of Active Subcarriers | Modulation (Active Profile) | First Active Subcarrier (Hz) |
159 | 96 | 4K | 1880 | QAM4096 | 759 |
Channel ID | Lock Status | RxMER Data (dB) | PLC Power (dBmV) | Correcteds (Active Profile) | Uncorrectables (Active Profile) |
159 | Locked | 38 | 4.3 | 2038652520 | 3699 |
3.0 Upstream channels
Channel | Frequency (Hz) | Power (dBmV) | Symbol Rate (ksps) | Modulation | Channel ID |
1 | 32600000 | 43 | 5120 KSym/sec | 64QAM | 5 |
2 | 39400000 | 44 | 5120 KSym/sec | 64QAM | 4 |
3 | 46200000 | 44.8 | 5120 KSym/sec | 64QAM | 3 |
4 | 53700000 | 45.8 | 5120 KSym/sec | 64QAM | 2 |
Channel | Channel Type | T1 Timeouts | T2 Timeouts | T3 Timeouts | T4 Timeouts |
1 | US_TYPE_STDMA | 0 | 0 | 1 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 1 | 0 |
Time | Priority | Description |
Thu 16/06/2022 08:40:29 | 3 | No Ranging Response received - T3 time-out;CM-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Thu 16/06/2022 08:40:37 | 6 | CM-STATUS message sent. Event Type Code: 4; Chan ID: 9; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC= CM-QOS=1.1;CM-VER=3.1; |
Thu 16/06/2022 08:40:37 | 3 | No Ranging Response received - T3 time-out;CM-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Thu 16/06/2022 08:41:09 | 3 | Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Thu 16/06/2022 08:41:09 | 3 | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=;CMTS-MAC=:23;CM-QOS=1.1;CM-VER=3.1; |
Thu 16/06/2022 08:41:29 | 3 | Ranging Request Retries exhausted;CM-MAC=;CMTS-MAC=00:;CM-QOS=1.1;CM-VER=3.1; |
Thu 16/06/2022 08:41:29 | 3 | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=;CMTS-MAC=3;CM-QOS=1.1;CM-VER=3.1; |
Thu 16/06/2022 08:41:49 | 3 | Ranging Request Retries exhausted;CM-MAC=;CMTS-MAC=00:;CM-QOS=1.1;CM-VER=3.1; |
Thu 16/06/2022 08:41:49 | 3 | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Thu 16/06/2022 08:42:29 | 3 | No Ranging Response received - T3 time-out;CM-MAC= CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Thu 16/06/2022 08:47:50 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC= CM-QOS=1.1;CM-VER=3.1; |
Thu 16/06/2022 08:54:16 | 6 | CM-STATUS message sent. Event Type Code: 5; Chan ID: 22; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Thu 16/06/2022 15:09:11 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Thu 16/06/2022 15:09:15 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Thu 16/06/2022 15:09:20 | 6 | CM-STATUS message sent. Event Type Code: 5; Chan ID: 5; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Thu 16/06/2022 15:10:28 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC= CM-QOS=1.1;CM-VER=3.1; |
Thu 16/06/2022 15:10:33 | 5 | Lost MDD Timeout;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Thu 16/06/2022 15:10:43 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 16/06/2022 15:11:08 | 5 | Lost MDD Timeout;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Thu 16/06/2022 15:11:17 | 6 | CM-STATUS message sent. Event Type Code: 4; Chan ID: 2; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Thu 16/06/2022 15:11:46 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Thu 16/06/2022 15:12:02 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Thu 16/06/2022 15:15:36 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Thu 16/06/2022 15:15:41 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC= CM-QOS=1.1;CM-VER=3.1; |
Thu 16/06/2022 15:26:01 | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Fri 17/06/2022 02:00:23 | 6 | CM-STATUS message sent. Event Type Code: 5; Chan ID: 2; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Fri 17/06/2022 02:02:18 | 3 | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC= CM-QOS=1.1;CM-VER=3.1; |
Fri 17/06/2022 02:02:18 | 3 | No Ranging Response received - T3 time-out;CM-MAC=e4:57:;CM-QOS=1.1;CM-VER=3.1; |
Fri 17/06/2022 02:03:16 | 6 | CM-STATUS message sent. Event Type Code: 5; Chan ID: 4; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Fri 17/06/2022 02:12:20 | 3 | No Ranging Response received - T3 time-out;CM-MAC=e4:57:;CM-QOS=1.1;CM-VER=3.1; |
Fri 17/06/2022 02:12:51 | 6 | CM-STATUS message sent. Event Type Code: 5; Chan ID: 4; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Fri 17/06/2022 02:14:16 | 3 | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC= 23;CM-QOS=1.1;CM-VER=3.1; |
Fri 17/06/2022 02:14:17 | 3 | No Ranging Response received - T3 time-out;CM-MAC=e4:57:;CM-QOS=1.1;CM-VER=3.1; |
Fri 17/06/2022 02:14:36 | 6 | CM-STATUS message sent. Event Type Code: 5; Chan ID: 4; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=;CM-QOS=1.1;CM-VER=3.1; |
An engineer was here around the time the problem started too, to install in a neighbour's flat. Could there now be too many on a splitter? A previous engineer had put my direct but I now can't find my cable.
on 27-06-2022 08:50
Hi tony22,
Thank you for your post. I'm very sorry for the issue you've been having with your Broadband service.
I have taken a look on our system and it looks as though a technician visit maybe needed.
I will private message you to confirm some details and look into this further.
^Martin
on 28-06-2022 10:36
Thank you for chatting with me over Private Message.
Please keep us posted on the engineer visit.
^Martin
