on 09-09-2021 12:05
We were reconnected to virgin on 16th August, and since then have experienced repeated drop outs, and bouts of high packet loss. BQM graphs are here Share Live Graph
This morning the connection dropped for 40 minutes before becoming stable again.
Router stats are after rebooting this 15 minutes ago
1 | 659000000 | -1.5 | 38 | 256 qam | 32 |
2 | 475000000 | -1.5 | 38 | 256 qam | 9 |
3 | 483000000 | -1.2 | 38 | 256 qam | 10 |
4 | 491000000 | -1.2 | 38 | 256 qam | 11 |
5 | 499000000 | -1.2 | 38 | 256 qam | 12 |
6 | 507000000 | -1.5 | 40 | 256 qam | 13 |
7 | 515000000 | -1.2 | 40 | 256 qam | 14 |
8 | 523000000 | -1.5 | 38 | 256 qam | 15 |
9 | 531000000 | -1.7 | 38 | 256 qam | 16 |
10 | 539000000 | -2 | 38 | 256 qam | 17 |
11 | 547000000 | -2.4 | 38 | 256 qam | 18 |
12 | 555000000 | -2.7 | 38 | 256 qam | 19 |
13 | 563000000 | -3 | 38 | 256 qam | 20 |
14 | 571000000 | -3.2 | 38 | 256 qam | 21 |
15 | 579000000 | -3.5 | 38 | 256 qam | 22 |
16 | 587000000 | -3.2 | 38 | 256 qam | 23 |
17 | 595000000 | -3.4 | 38 | 256 qam | 24 |
18 | 603000000 | -3.2 | 38 | 256 qam | 25 |
19 | 611000000 | -3.2 | 38 | 256 qam | 26 |
20 | 619000000 | -3 | 38 | 256 qam | 27 |
21 | 627000000 | -2.9 | 38 | 256 qam | 28 |
22 | 635000000 | -2.5 | 38 | 256 qam | 29 |
23 | 643000000 | -2 | 38 | 256 qam | 30 |
24 | 651000000 | -1.9 | 38 | 256 qam | 31 |
1 | Locked | 38.9 | 0 | 0 |
2 | Locked | 38.6 | 6 | 0 |
3 | Locked | 38.9 | 5 | 0 |
4 | Locked | 38.9 | 5 | 0 |
5 | Locked | 38.9 | 4 | 0 |
6 | Locked | 40.9 | 0 | 0 |
7 | Locked | 40.3 | 5 | 0 |
8 | Locked | 38.9 | 3 | 0 |
9 | Locked | 38.6 | 6 | 0 |
10 | Locked | 38.9 | 4 | 0 |
11 | Locked | 38.6 | 12 | 0 |
12 | Locked | 38.6 | 4 | 0 |
13 | Locked | 38.6 | 5 | 0 |
14 | Locked | 38.9 | 5 | 0 |
15 | Locked | 38.9 | 0 | 0 |
16 | Locked | 38.6 | 14 | 0 |
17 | Locked | 38.9 | 11 | 0 |
18 | Locked | 38.6 | 5 | 0 |
19 | Locked | 38.9 | 5 | 0 |
20 | Locked | 38.6 | 5 | 0 |
21 | Locked | 38.9 | 7 | 0 |
22 | Locked | 38.6 | 4 | 0 |
23 | Locked | 38.9 | 6 | 0 |
24 | Locked | 38.9 | 14 | 0 |
1 | 53699935 | 38.5 | 5120 | 64 qam | 2 |
2 | 39400029 | 38.5 | 5120 | 64 qam | 4 |
3 | 46199910 | 38.5 | 5120 | 64 qam | 3 |
4 | 60300051 | 38.5 | 5120 | 64 qam | 1 |
on 09-09-2021 14:18
on 09-09-2021 14:20
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
https://www.thinkbroadband.com/broadband/monitoring/quality/share/807cf1956f98f5da0f1d2c30a2486dd9a0422a4d
09-09-2021 14:33 - edited 09-09-2021 14:34
Stats all look good as does the BQM - Except for a large "wobbly" between 11.00-12.00
What do the Network Logs report for that period?
Were you doing anything "unusual" in that period ?
on 09-09-2021 14:43
this is the network log for the period
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; | ||
09/09/2021 11:25:34 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 11:25:28 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 11:25:27 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 11:25:27 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 11:25:26 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 11:25:26 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 11:25:25 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 11:25:25 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 11:25:23 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 11:10:46 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 11:10:11 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 11:10:6 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 11:10:6 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/09/2021 11:10:5 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
on 10-09-2021 14:52
on 13-09-2021 10:29
Good morning @andyleadbetter.
Welcome back to the forums and thank you for taking the time to post.
I am sorry to hear that you have had some issues with your services.
How are things looking at the moment? Is your BQM link still live?
Kind regards,
Zak_M
