Smoocher
Message 1 of 5
Exceptionally Slow Connection Speed
Hi - I see there are several people posting similar posts. I'm paying for 200mb connection and are crawling at 9mb download and as slow as 1.4mb upload. We run a dog rescue website so connection speeds are critical to getting work done smoothly. The current upload speeds are doing my head in. Any help greatly appreciated. I've rebooted the router several times, no improvement. ThinkBroadband.JPG
Smoocher
Message 2 of 5
Re: Exceptionally Slow Connection Speed
SCA1972
  • 5.78K
  • 654
  • 1.94K
Message 3 of 5
The downstream power levels are a bit too high on three of the channels.  The recommended range is -6 to +10.
This will probably need a technician to visit and adjust the power levels.  Normally I'd say you can call VM and try to book a visit but lines are very busy during the current crisis and it might be a struggle to get through.
Alternatively you can wait for the VM forum staff to get to this thread and they can help you book a visit.
______________________
Scott
My setup: V6 TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
Eeeps
  • 755
  • 47
  • 118
Rising star
Message 4 of 5
As has been suggested your downstream power levels are a little to high and will need reducing by an engineer.
However, it seems you have an older modem, is there a reason for that? A SH3 would bond 24 downstream channels giving it a better chance of obtaining full rate.
Could you post the modem configuration. From this you can confirm that you are on the correct speed.
Your speed test seems to be limited to 10Mb/s down stream.
Smoocher
Message 5 of 5
Phoned VM the waiting times weren't very long and they are now sending a new Router in a couple of day's time. Fingers crossed this will do the trick.
