nhumphri
  • 6
Message 1 of 10
Dropped packets and high latency - practically unusable at peak time
Hi there
The quality of our 100mb/s broadband connection has been really bad this week making it unusable at peak times. In desperation we've all been hot-spotting from our phones!
What I've tried:
  • Rebooting hub
  • Resetting hub to factory default
  • Virgin status page - says everything's fine
I've set up a service to monitor ping responses to my public router IP and it's clearly showing heavy packet loss and high latency at peak times:
This is what I'm used to seeing when its working:
What's the best way of ensuring this problem is acknowledged by Virgin Media and getting a fix ETA?
Last time I rang they said everything was fine and the helpline wouldn't even connect today!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 10
Re: Dropped packets and high latency - practically unusable at peak time
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 10
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
nhumphri
  • 6
Message 4 of 10
nhumphri
  • 6
Message 5 of 10
1539000000-338256 qam17
2547000000-338256 qam18
3555000000-3.238256 qam19
4563000000-2.738256 qam20
5571000000-2.738256 qam21
6579000000-2.737256 qam22
7587000000-2.537256 qam23
8595000000-2.438256 qam24
9603000000-2.238256 qam25
10611000000-2.538256 qam26
11619000000-2.738256 qam27
12627000000-2.738256 qam28
13635000000-2.237256 qam29
14643000000-1.937256 qam30
15651000000-237256 qam31
16659000000-237256 qam32
17667000000-2.437256 qam33
18675000000-237256 qam34
19683000000-237256 qam35
20691000000-1.937256 qam36
21699000000-1.937256 qam37
22707000000-2.237256 qam38
23715000000-2.237256 qam39
24723000000-2.237256 qam40
1Locked38.6120
2Locked38.990
3Locked38.6220
4Locked38.690
5Locked38.6160
6Locked37.690
7Locked37.6120
8Locked38.6120
9Locked38.6100
10Locked38.6120
11Locked38.6100
12Locked38.660
13Locked37.6180
14Locked37.6110
15Locked37.380
16Locked37.680
17Locked37.6200
18Locked37.6120
19Locked37.6120
20Locked37.690
21Locked37.6210
22Locked37.6100
23Locked37.3130
24Locked37.6100
13940000041.5512064 qam6
24619990842512064 qam5
33260000041.3512064 qam7
42580053641.3512016 qam8
1ATDMA0020
3ATDMA0000
4ATDMA0010
nhumphri
  • 6
Message 6 of 10
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057-b.cm
SFID203684
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID203683
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
07/01/2021 17:29:13noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 23:50:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 23:19:31noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 23:12:37noticeUnit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 23:11:23noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 21:49:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 19:05:16noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 17:24:17noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 17:23:39Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 17:17:36noticeUnit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 16:45:19noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 15:12:12criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 15:11:48criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 15:11:47criticalRanging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 15:05:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 15:04:59criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 15:04:59criticalRanging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 14:58:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
nhumphri
  • 6
Message 7 of 10
Is there anything else you need? It's no better this week 😞
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 8 of 10
Your >> BQM << is a mess, I'm thinking that there are possibly two things affecting your connection.
Firstly, it looks like you are in an area of high utilisation.
Secondly it looks like you have a lot of noise / bad connection on the line.
Try a reboot to see if the Hub can renegotiate a better connection using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
While the Hub is powered off go around all the accessible co-ax connectors inside and outside to ensure that they are finger tight.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your connection again.
nhumphri
  • 6
Message 9 of 10
Tried all that but same story today. I've got an engineer booked for Monday. Assuming this is a fault that can be fixed, is there anything else I should do to help fault finding or suggest to the engineer?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 10 of 10
Not really,
